Enjoy this idea
Bart Leetch
http://www.youtube.com/watch?v=RX-kp-HZ5UQ&feature=channel&list=UL
Enjoy this idea
Bart Leetch
Eine interessante Methode! Exzellent!
Re: Enjoy this idea
Mike Stafford
The use of polyurethane foam as a backer and to support the piece of burl is ingenious.
However, let it be said that Big Mike is a chicken and will never stand in front of a contraption such as the one used in that video.
One other note, when he was removing the bowl from the holder it was obvious that he did not have sufficient turning muscle to help support the piece.....
Wonder what speed it was turning at?
Steven Antonucci
Looked pretty low. Even the slowest speed on my Nova (214) would probably be pretty scary. Wonder if Terry Scott has seen the foam thing?
I sent Terry the link....
Mike Stafford
He should find numerous applications for that idea1
Re: I sent Terry the link....
DLeydens
Steve and Mike, you took the words right out of my mouth with The Terry Scott involvement. But could
boat anchors and anvils really be replaced by foam?? Don't know if Terry would go for it.
I wonder how he keeps the expanding ...
JamieDonaldson
...foam from popping the burl out of the frame as it cures?
Re: I wonder how he keeps the expanding ...
Mike Stafford
Jamie, I, of course did not see him place the piece in the box with the foam but I would not be surprised if he wrapped the piece in plastic, loaded in the frame, screwed the retaining pieces in place and then filled the cavity with foam being careful to keep the burl blank centered as it expanded. Any foam that expanded beyond the box could easily be trimmed away with a knife or saw before turning.
This is pure speculation on my part.....
Randy Gleckler
Expanding on Mike's thoughts..... ;-) couldn't help it.
I also was not there, but can't help but think, with the flat front and to keep the pieces flat faced to the front, perhaps he built the frame upside down... filled and allowed it to expand to the back, trimmed it, and then put the backer plate on and mounted it to a faceplate. This way he ensured it was filled in where needed up to the back plate and even with the front when he started.... Course maybe not.
There was an article in a magazine too many years ago for me to remember the specifics. It was about turning frail pieces I believe. I remember trying it. You can simply squirt the foam a little at a time and let it expand against the piece. It will flow toward any open area and doesn't firm up until it hardens.
there are also many varieties of this foam. What we know here is Great Stuff that firms up very solid. The stuff they used to ship my really fragile piece at a shipping warehouse appears the same but you can stick you finger 4" deep into it because it's kind of fluffy rather than hard.
My Chemist friend actually mixes the stuff as part of their magic show. They can make it foam with more or less air by simply changing the amount of the chemicals. What they mix for the show grows about 50 times the size of the container they start with and flows all over the counter and then hardens to a very soft foam.
And now you'll hear the rest of the story
MY wife had seen me use the foam for several different projects and she wanted to make Volcano for her science class students. She started squirting the foam while I mowed the yard. Apparently as the foam expanded it started flowing and she was losing the shape of the Volcano so she used her hands to move it back up the slope and shape the Volcano.
Now here is where I should tell you that Great Stuff foam is just a different formulation of the same chemicals that go into Gorilla Glue. Well she comes to me and can't move her hands and can't get the foam off. We tried every solvent I had, I have a bunch. Nothing even came close to softening that stuff. She spend several days peeling it off her hands and actually pulling thin layers of skin off.
Plain DNA
Jorge
Denatured alcohol does a good job of cleaning before the foam sets.
That is what I use to clean gorilla glue mess.
Re: Plain DNA
Before it sets. Nothing touches it afterwords. I tried everything from Gas to Lacquer thinner. I probably have 10 different solvents.
Very Cool!
Don Orr
I gather that this is not his first time using this method. The spinning unit looks well balanced and secure. I like the outboard setup he uses too. I see several blanks prepped in the background. The expanding foam is a great idea as long as you use the barrier between it and the wood. Nice work!
