Don't know about you, but what I see when a piece is on the lathe and what I see when it's vertical are often a bit different. This looked pretty good - on the lathe. Seeing it vertical, I see the neck needs a bit longer, needs more thinning and I need to reduce the diameter of the area just below where the tip flame will go.
I also find that things look different in horizontal and vertical orientations. I have a small Apple hollow form that needs to go back on the lathe because I wanted to finish it, and didn't take the extra time to evaluate it standing up, and now I don't like the form quite as much as I thought I would.
Your "mini-al" is shown upside down, I assume?
I like the shape so far; It looks like a Maple or possibly White Birch (?) Is there a finer-grained light-colored wood for these ? I wonder if Boxwood or Hophornbeam or Lilac would hold up to such tiny details... I have some small pieces of all of these I could mail to you if you would like to try them. Send me an e-mail with your address if you would like some to try.
Then again, John Lucas would probably use rice-wood, but he seems to have Lee Major's eyesight!
Brad I cheat, I use magnifiers. I can't see my hands in front of my face without glasses.
The interesting thing about turning really small is that you can get failures and good wood out of the same 1" of log. It simply depends on the structure of the wood and where any defects fall in relation to the turning.
For example when I first started using Cherry I broke nearly every goblet. Then when I got super tiny I tried the cherry out of frustration because I had broken 4 or 5 in a row using ebony and yellow heart. The cherry I got this time worked perfectly and I turned a goblet about the size of the tip of Charlie's finial.
Just grab a piece and start. Woods with pores don't work. Things like Walnut, Oak and even Mesquite (which I thought would be good). If one of those pores ends up in the stem or lip of the goblet it blows. up. Kind of like what a knot does in full size wood if it's in the wrong place.
Thanks for the offer of wood. This finial is in maple and it seems to be holding up well - so far. I'm going to hit The Saw Dust Shop and check out their pen blanks. Neat thing about miniatures is you can use pen blanks and other smaller pieces of wood - that are usually much less expensive - when small.
Yes, the image of the finial I posted earlier is upside down - still in the chuck. Since this finial has to fit in the hole in the top of the Flat Top HF, getting that fit right was what was turned first. It would be frustrating as hell to turn a really nice little finial - and then overshoot or undershoot the tenon that should fit in the opening in the HF.
It would be better to turn from the most delicate, tip of the finial back towards its base - but the Fit Thing was critical so I had to turn from it back to the tip.
Orientation can trick the eye - as demonstrated in this image. (1) on the lathe looks sort of good. (2) shows where things seem not quite right. (3) CLEARLY shows that the base of the "onion" is too big and not shaped right - and that the neck needs thinning and lengthening. (4) shows those changes - thought the neck still needs some more thinning.
