Vacuum Pump Question
dick gerard
Just how warm/hot should a Gast vacuum pump housing get? Mine was a retirement gift from my wife back in dec. 04. At times, it runs for the better part of an hour. I have noticed that the housing is warmn (I'd estimate around 90-100 degrees F.) Is this normal? Not looking for trouble, just curious.
Re: Vacuum Pump Question
Chuck Engstrom
Hi Dick -- I'm inclined to think that anything you can still hold your hand on without discomfort is probably OK, though I don't have specific experience with Gast vacuum pumps.
Best--
Chuck
Scott Crumpton
Here are a couple numbers that may help you decide how hot is too hot.
A NEMA insulation temperature tolerance class A (the lowest rated class) motor is rated to operate at up to about 220 deg F. I don't know the rating of the Gast motors. Import motors are probably not as good.
Anything over 120 deg F can get painful quickly if you're sensitive. 130 and up can quickly result in burns if the heat transfer rate is good, like with damp hands.
So yes, if you can keep your hand on it it's ok is correct and leaves a good margin for error.
Bill Turpin in WNC mountains
Many motors are rated at 40°C rise above ambient. That is 104°F. So if your shop is 80°, then a motor temp of 184° is OK. Look on the nameplate, usually found there.
Dick Mine is an older unit I got from the Flea mkt. It runs quite hot. Not too hot to touch but you wouldn't want to leave your hand there long. I keep wondering if it has a thermal cutout but so far it's never shut off. I am planning to build a cabinet for it to sit in under my lathe and I'm going to mount a cooling fan in the cabinet just in case.
Harry Robinette
Harry Robinette
Dick
I put a hose on the exhaust port on mine and direct the air back over the unit. Mine now runs cooler.
Hope this helps.
Dave Paine
I have an oil lubricated Gast 522, if I run mine for a long time, for me perhaps 20 mins, it gets warm like yours.
I like the idea of the other person to pipe the exhaust back over the unit. I will give this a try.
I feel if it is not too hot to touch, it should not be a problem.
Doug Turner
Dick, I used the same Gast motors on air samplers for over 45 years and we ran some 24 hrs/day, 365 days straight without incident in very dusty atmospheres. Then changed the bearings, carbon vanes & filters and put them back into continuous service. They lasted several years under this service conditions.
They do run warm, but I have never seen one get hot enough to do damage unless the bearings seize. I use a Gast on my vacuum chuck and it works like a champ.
Doug Turner
dick gerard
Thanks everybody! I knew I could count on thw Woodies!
