THE WOODRAT IS BACK!
Finishing with Beeswax
Tom
Need some advice/suggestions on how to finish turned items with beeswax. Probably pretty easy but thought someone out there would have experienced use of beeswax.
Appreciate your time! Tom
Re: Finishing with Beeswax
Don in Central Illinois
Just sawca short video on food safe finishes, which included beeswax, from Craft Sopplies on facebok. If not on face book, try looking for Craft Supply on youtube. Sorry don't know how to provide links.
Peter Charles Fagg (UK)
For more years than I care to remember I used pure beeswax as my finish, it is OK but will not tolerate a lot of handling etc. and water drops are a pain!
Anyway, if you melt it on to the spinning wood covering with an even layer, not too thick!
Then I turned up the lathe speed and using several pieces of cloth or soft paper I removed the wax or at least most of it until I was getting only the slightest hint of wax on the cloth or paper.
For the final buffing I used a very soft lint free cloth and hand polished the piece off the lathe.
It does give a warm glow to the wood but does not lend itself to handling at shows etc. finger marks tend to show up easily.
Regards Peter.
Peter Hyde
Do it as Raffan does. Slop on some oil with the lathe at speed wipe it off then melt the beeswax into the wood with the heat from friction and finally use a piece of rag to remove excess. Keep the rag for future uses as it gets loaded and will eventually be all the finish you need.Gives a low lustre which is good for not showing scratches you missed when sanding. DAMHIKT :)
Tom
Thanks to all for your responses! Will now give it a go!!
Tom
