I'm wondering if anyone has had any experience in loading 35mm slides onto a computer. I enjoy burning pictures onto my turnings and I have a lot of nice pictures that I took years ago that I could convert to line drawings. I'm not a computer genious my any stretch but I can usually fumble my way through the simple stuff. Any suggestions on equipment or needs?
I made this simple gizmo to hold the camera via the tripod screw hole so a slide fills the frame of the camera when in macro mode. Halogen floodlights were shone on the white plastic reflector. I could do slides very quickly and the quality was quite satisfactory.
ok, those suggestions will get the photo into the computer but how do you then convert it to a line drawing? I am in the same boat as Bill except I don't have trouble getting to the computer but converting to a line drawing takes software I don't have. Anyone doing this? If so what are you using?
Any draw program that has a bezier tool. You just trace over the photo reducing it to the lines you need. Tedious but the best way. CorelDraw is still around and the older versions will incorporate a Trace program which sort of does the same thing. Most of the graphics programs also have artistic effects that will reduce photos to line drawing to simulate charcoal or pencil or pen and ink lines.
Thanks for the responses guys. As far as getting line drawings, I use a photo program called "Picassa". It came with my camera. I just got an upgrade of Picassa and it includes a button for converting to line drawing. I have had software for this before but nothing compares. Picassa will do exactly what I want to achieve drawings for pyrography on turnings.
I have imported hundreds of prints and slides using a scanner. Any scanner with a rack for slides will do. BUT it's the software that makes all the difference. I have been using Vuescan since day 1 and it makes life really easy. Set up all the correction parameters and do a batch scan 5 at a time. Vuescan is cross platform and you get lifetime updates free with the pro version. Try it for free.
Thank you to everyone for your responses. They give me plenty to work with. Hal, I have "Picassa 3". If you pick a picture to print, there is a list on the left side of the screen that lists adjustments such as red eye removal, fill light, color correction, etc. At the top of that list, there 5 small squares marked with a wrench, the sun, and the last 3 are paint brushes. The one on the right is marked, "even more fun .... ". Click on that one and you will see several choices, one of which is line drawing. There are adjustments that will vary the intensity.
If you have an older version of Picassa, you can get a free upgrade. If you need it, let me know. I don't have it handy, but I can get it for you tomorrow evening.
I hope this helps and thanks again to all who helped.
I've been using their Vueprint32 Pro for years, I believe it was $40.00 originally and all the upgrades have been free. It also includes "scanning ability. I use this program for "resizing" photo's for posting them on internet sites, forums, etc.
