Ginger Jar - Neglected Hollow Form
charlie belden
While other ceramics inspired pieces show up all the time, for some reason, the turned ginger jar form is unusual. When the form is seen, it's usually with a fiinialed lid. In porcelin, it's a much more common piece and I have a couple that are cloissone enameled on bronze. At some point in history, ginger must have been an expensive item, to be protected in something durable - and nice to look at.
This jar is manzaneta, the lid in a mystery wood I had on hand, after running out of manzaneta. Would have been a more coherent piece if the lid was of the same wood and with the same look as the jar. The jar is hollowed pretty thin. My first attempt at a ginger jar ended up with walls TOO thin. Apparently, the Inside Diameter is supposed to be kept LESS THAN the Outside Diameter. That intended ginger jar became a shallow bowl - and a ring of wood that I may find something to do with at some future date.
The Ginger Jar form seems to clean and simple. Doing one that looks right - not quite so simple. The form is great for showing off figured wood, dyeing, texturing, carving, pyroing, etc.. Why it isn't more common is a mystery to me. Maybe it looks too easy?
Unlike the Flat Top HF posted earlier, on THIS one, I got the lip of the rim TOO THIN. But a thicker rim meant a larger OD for the lid and thus a larger lid than I had in mind
I need to figure out a way to avoid the flat on the lid and go with a flat oval instead. The piece would look better with a slightly smaller foot.
Here's the piece, sittinig on a nickel for scale.
Comments, suggestions, constructive criticism welcomed.
