Need some ideas
D. Hansen
Looking for some innovation and or ideas to solve a dilemma. Here is the situation. I turned a 12" or so cherry natural edge bowl. Turned out very nice and I don't want to relegate it to the fireplace. When I turned off the bottom I ran in to an unexpected worm hole. (maybe i should call Morton Freeman??) . The vacuum chuck pulled a portion of the center of the bottom in along the worm hole so now I have a funnel.
I thought about turning a stepped bottom of some sort and epoxying it to the bowl like a step. Maybe turn a small tennon to fit the bowl bottom and do some chatterwork or carving so that when installed the inside of the bowl would have a decorative item in the bottom. I could also just make a cabochon and glue it over the hole I guess.
I have a set of cole jaws but have never used them. I was thinking about mounting the bowl in the jaws and turn the hole crack circular so the new stepped bottom tennon would fit the hole.
The problem is that the bowl top is irregular. It is natural edge with bark all around it. Although I have not worked out the details I kinda think the bowl will not be stable enough in the cole jaws to allow me to make the hole neat enough for the tennon. I thought about making a donut chuck but it would probably present the same problem So I thought that maybe someone on W/C might be able to suggest some things I could try to salvage the bowl. thoughts ideas and or suggestions welcome.
