Inside bowl rests...
robo hippy
I watched several bowl turning demos in San Jose. I was amazed that a lot of turners prefer to use a straight tool rest on the inside of bowls, preferring to extend the bowl gouges out much farther off the rest rather than using the curved rests. Reasons vary from 'it is inconvenient' to 'i keep running into the post'. I do find this a bit confusing, because when we teach, we continually tell students to keep the tool rest close to the wood for better tool control. I am wondering if this preference is due more to the inside tool rests just are not made in the proper shapes than anything else.
This is my favorite shape. I love the recurve on both ends. The one near the rim allows you to work all parts of the rim, then turn down the sides of the bowl, and then another recurve to go through the transition and across the bottom of the bowl. The main down sides to it are the very wide cross section, and it being made with cast iron rather than the drill rod tops.
I have the Oneway bowl rests. The large one is fine, but does tend to chatter a bit when you are working out on the very end except for all but very light cuts. Shape is okay. It is not an arc of a circle, but a slightly straight section, then the curve. If they were to weld a support finger under the rest, like the one under their coring blade, that would easily solve that problem. No recurve on the top, which does cause some 'interference' problems for working the rim and the inside without multiple moves of the banjo and tool rest.
I have the Robust tool rests, and I love the drill rod, there is no vibration out on the tip, no matter how big of a cut you are making. It is an arc of a circle, about 6 inch diameter. Same interference problems.
I do like that the support finger on the Robust angles away from the drill rod rather than being straight up and down, which would keep you farther away from the wood. I am trying to convince Brent to make a tool rest for inside bowls similar to the Craft Supplies rest.
What do you do on the inside of bowls? What is your favorite inside rest? What do you teach?
robo hippy
