Found a bunch of spalted elm over the week end but run out of sealer. Mixed some Elmers white glue and water up and used it for an emergency....anybody ever tried that, thought about some Thompson's wood sealer but thought it might have too much penetration. What alternatives have you tried?
I now have some log sections under tarps. I have used old oil finishes which are okay, and have had great success with Thompson's Water seal, and have some of the logs with Titebond 2 on them. Will report on this in several months.
I used some leftover latex wall paint, primarily to get rid of the nearly-empty can. It worked ok, but not as well as anchor seal. In the future I might try it again for short-term use, but not for something that would be kept for a longer period of time.
Diluted yellow woodworkers glue. Tended to crack open fairly quickly and the logs still cracked. May have not dilluted it enough. It was also kind of expensive.
Roofing tar, just because I had it. Worked great, extremely messy. did I say messy.
Caulking, again because I had it. Worked great just too expensive to use in quantity.
Plastic garbage bags. Works really great in a pinch. I set the logs with one end on the ground and put the bags over the other end with a bungee cord around them. You do get mold and the logs will spalt but it lasts until the bag deteriorates from the UV light. This is my short term storage until I can get the time to seal the ends with anchorseal and put a tarp over them.
So far just laying a tarp over the logs has worked about as well as anything for short term storage. Looks like hell having blue tarps all over the driveway but those things are so cheap now.
I use paraffin wax on the end grain. You would think that would stop it from losing moisture. Nope. Even bowl blanks that I totally cover with paraffin lose weight over a few months or longer. It does slow down drying tremendously and the bowls that I've turned after a few months or longer still turn like green wood.
.....and logs on the driveway are some of the universal locating features of a woodturner's residence! (Bags or piles of shavings is the other!)
My friends have learned to find my house for the first time by spotting the logs and blue tarps on the driveway and along the side of the garage. I recently have been buying the reversible green/brown tarps which fit-in to normal "neighborhood colors" better, and don't stand-out as much as blue tarps do.....
.....also less complaints from SWMBO using green/brown tarps than the blue ones. (Free hint for those in similar situations! )
One of this summer's projects is the construction of a 4 ft. x 12 ft. "firewood" shed next to the garage to house log sections and turning blanks a bit more attractively than the blue tarp solution. Even after I build it, I think there will still be some 'tarpage' going on at my place from time to time.
As others have mentioned, I would try using the glue undiluted in order to get more of the latex in the coating. Paraffin coats well but needs to be scraped off. End Seal, which I think is an emulsified paraffin (probably equivalent to Anchorseal) goes on easy with a roller and works. Latex paint would likely need several coats to get enough latex deposited, depending somewhat on the quality of the paint (percentage of latex), I tried one coat of inexpensive latex paint and wasn't satisfied with the results. Even something like the latex additive for cement mixtures, which has a high concentration of latex per volume would probably work (I haven't tried this yet). Also as already mentioned, how long you need to store something can dictate the easiest and most cost effective method, as well as how much loss due to checking you can tolerate and the climate in which you store it.
Why does paraffin have to be scraped off? I'm using it on rough turnings or on bowl blanks. I just cut it off as I'm turning. About the only downside of using so far is on larger pieces that won't fit in my skillet. I use a coffee can that has the wax in it. I sit it in my electric skillet that already has wax melted. then the wax in the can melts I can spread it with a brush right out of the coffee can.
I don't do that much since I still have a good supply of Anchorseal.
I had a feeling someone would ask this question. Naturally, the way you use it wouldn't require scraping off and being able to dunk in liquid wax at a reasonable temp would give something like I have seen on commercial blanks. When I've used it on green wood ends outside, it tends to cool too quickly and thus it "builds up" a thick coat by the time all the surface is sufficiently coated. I have been able to alleviate that by "flaming" carefully with a hand held propane torch but that complicates the process. The way you use it there would not be much mess or chance that you could get paraffin on something that you didn't want to get paraffin on and/or add to the fire hazard in a heated shop when mixed with dry shavings. So, to sum up, I agree with you.
