(Message Deleted by Poster)
Re: (Message Deleted by Poster)
Re: Different Twist on Drying Roughed Out Turning
I've never tried the DNA method but I anchorseal the end grain sections of the bowl both inside and out. If it's a crack prone wood like cherry I also anchorseal the lip and tenon or foot. This has worked very well for me on bowls over the last few years. It probably does slow down the over all drying time but that's fine with me. I have a stack of about 30 bowls that are dry right now so I can rough turn whatever I want and put it up on the shelf. Then just grab a dry one and finish turn that one.
Jorge
Phillip,
I leave them alone with nothing, just in a quiet spot with an even temperature and no air currents, some of them will check no matter what, like cherry or apple, but most, including cherry and apple, will dry faster without a problem, some in as little as 3 weeks.
It is faster and a lot more economical, alcohol is expensive.
Bill Howatt
I don't use any DNA. Rough turn and typically Anchorseal the outside end-grain. If it is a piece that is particularly important for any reason I may do the inside end-grain as well.
While there is an emphasis on slowing the drying, I find it is just as important to monitor the early stages of drying to ensure that black mold is not starting.
Some wood will crack no matter what you do and sometimes it happens with a wood that normally doesn't give you a problem. Probably because of stresses built up due to how/where the tree was growing.
Bill
David Walser
Phillip,
I suspect what will work best for you will be highly dependent on your local climate -- which may vary with the season. Here in Arizona, we only have two seasons: dry and not-quite-so-dry. In our summer monsoon season, humidity might be north of 40%. Otherwise, it's in the teens. My point is what works for turners in Arizona might not work (or be over kill) for you.
My suggestion is to try different methods side-by-side and see what works in your area.
Arghhhhh
Philip Morris
I tried to respond to my message to add more info and deleted the message. DRATS.
Thanks for all the responses and I apologize for the confusion that will result in having a string of responses with no original post. Oh, well.
Philip
Excellent Point!
Original Post (that I inadvertently deleted, duh!)
philip morris
I have used David Smith’s DNA soaking on a number of rough outs with generally good success. Where I have problems have been with woods prone to checking, such as fruit woods. It appears that David’s process is comprised of two components: 1) expedite drying (soak in DNA) and 2) control drying to prevent checking (wrap outside with paper so inside dries first).
With that said, if the priority was to prevent checking, does it make sense to rough out a piece and coat just the outside with something like Anchorseal?
Barry L Elder
I agree with David as to local climate variations. Several years ago I bought a 5 gal. can of DNA to experiment on drying speed of roughouts, as compared to the old 20# paper bag w/shavings. The end result for me was that in our humid/more humid environment here on the coast of Fla., the difference in drying time (by weight on my digital scale) was negligible. Certainly not worth the expense of the DNA. Anyone need a couple of gallons of DNA cheap? :D
Rich Egan
I have a new observation I will throw into the mix. I was having trouble with mold appearing on roughed green blanks, so I made up a diluted water/bleach solution in a spray bottle, and applied that to the next few roughouts before wrapping in a paper bag. No mold. I have done about 8 small cherry bowls this way, and a couple chinese elm as well. I not only have no mold problems, but I have also found no cracks or checks whatsoever. They are all drying very well. I don't know if this is because of being wet down with bleach, or that I am being more careful about wall thicknesses or cutting away all the pith. I'll have to experiment some more before I know.
Rodney
Dilute Lysol also works to stop the mildew, or likely any of the disinfectant sprays, not just that brand. Things that have been alcohol soaked for drying also don't seem to have a mildew problem and it would stop the fungus growth in spalted wood as would the boiling, soap solution, kiln drying methods.
Do you get any bleaching effect with the dilute bleach method?
