Serious Camlock Handle
David Walser
I use and endorse the Serious Camlock Handle. A 1/8 turn of the cam nut locks the tool in place. A 1/8 turn in the opposite direction frees the tool. It couldn't be simpler.
Here are some additional comments, both pro and con:
* I like the balance and feel of the handle. The foam grip does a good job of absorbing any vibrations. Yet, you still get a good feel of the tool's edge cutting into the wood.
* The handle uses collets to adapt to different tool shaft sizes. Changing from one collett to another is quick and easy, but I'd still recommend having one handle for 3/8" shafts, another for 1/2" shafts, etc. The collets are far too easy to lose among the shavings. (At least they are in my shop.) Besides, having to switch from one collet to another limits the quick change benefit of the cam lock.
* The collets do NOT have much adjustment capacity. The shaft size of the tool needs to be fairly close to the stated size or the collet might not grip the tool securely. I have an off-brand tool with an undersized shaft that is nominally 1/2" in diameter. I have to turn the cam nut close to a 1/4 turn to secure the tool. If the shaft were a little more undersized, I doubt the cam/collet would secure the tool.
* The collets allow you to slide the tool as far into the handle as you would like. This makes it easy to "choke up" on a tool or to extend it out for more reach. It also enables you to use double-ended tools. (My serious 1/2" spindle gouge has a flute that runs the full length of the tool. This enables each end to be ground to a different shape. I like this feature.)
* The cam locks with a 1/8 turn in either direction. If you don't always turn the cam in the same direction to lock the tool, it's easy to turn the cam in the wrong direction when trying to free the tool. This can easily make the cam too tight to unlock by hand. The cam and the handle body are marked to show the unlocked position. These markings are fairly faint and can be easily obscured by dust, so I've accented the marks with a Sharpie. Even still, when first using the tool, I'd forget to look and would inadvertently lock the tool into the handle. Just remember, if the cam resists turning, you're turning it the wrong way! Light pressure is all it takes to secure the tool and light pressure should be all it take to unlock it.
* The tool handle is round and is basically the same diameter from one end to the other. (Only the cam at the front of the tool is of a different diameter.) Unlike a custom made wooden handle or some of the other interchangeable handles on the market, there's no tactile feedback to let you know where you're gripping the handle or to know the direction of the flute. The handle will also roll off your lathe or bench.
* The handle is hollow it's full length. While this allows you to use double ended tools and to extend your tool the length you'd like, there is no ability to add lead shot or some other ballast to the tool. I don't like using such ballast, it makes the tool feel "dead" in my hands; but if you want to use lead shot, this isn't the handle for you.
* The handle does not accept extensions. It only comes in one length. At about 18", the handle is an acceptable length for most applications. But, it can be too short or too long for other uses. This cannot be the only handle in your kit.
HTH
