Respect the bandsaw...
GaryG in MD
One of our VERY experienced members came to the meeting tonight with his hand and arm all bandaged up. 'Nuff said...
GaryG in MD
Re: Respect the bandsaw...
Clay Foster
I know more wood turners who have been hurt on a bandsaw than a lathe, me included. Power tools are a hanging judge, no mercy or probation.
Jason Clark
Amen. There's a very good reason some of my friends call me "Pinky".
Jason
Ditto- I try to stay scared of that machine
I wish you would tell how.
Keith Newton
Hearing about an accident, is a good time to share and unexpected hazard, which might just keep someone else from making the same mistake.
What happened?
I never understand this?
Steven Antonucci
The only way you can get cut by a bandsaw is to put your hand into the blade while it is spinning? If you are never moving your hand towards the blade, it's just about the safest tool in the shop?
The closest to injured that I have ever come on the bandsaw is from cutting a log that was still round and the blade jammed and slammed it down on the table. Nothing like hitting your self with a 10 pound-2 HP sledgehammer.
But cuts? Should never happen.
Steve
Don Orr
Absolutely! I have tremendous respect and a healthy fear of the bandsaw instilled in me by my Jr. High shop teacher Mr. Grubel. As he was showing us the various machines the 1st week he took a piece of probably 1x pine and quickly slid it across the table and into the running blade and back out. It left a cut about 1.5" deep in the edge of that board in the blink of an eye. I can still see that action in my head some 40+ years later.
Also, Keith Tompkins wrote a very good article in the "American Woodturner" journal a few issues back. I use the "red zone" concept all the time now.
Hook tooth vs Skip Tooth
Doc Green
I recently installed an Olsen 3 tpi hook-tooth blade and soon discovered that it is far more aggressive than the 4 tpi Timberwolf blades that I normally use. The blade grabbed and buried itself in the wood. I had to cut it out with a chisel. First time ever I've had a bandsaw blade to grab.
Not just me - a friend of mine, a retired pattern maker and expert bandsaw person, also observed that the blade was "very grabby," and this was after I had removed a lot of the hook by resharpening the blade with a Dremel tool. I refused to use the blade any more.
Later, I learned that the tooth geometry of the Timberwolf blades is not a pure hook tooth but is their own design that is less grabby than a hook tooth.
So, it appears that the tooth geometry and pitch are very important. I will never again use a 3 tpi hook tooth. I will use a Timberwolf 4 tpi blade, or a 4 tpi skip tooth blade made by another manufacturer.
The bandsaw is the only tool in my shop that I'm afraid of. ~Doc
Dan Jechura Temperance Mich.
I did that 4 months ago. 3 fingers and 6 stiches later I was good to go. No real damage just skin. Was cutting out a bowl blank, late in the day, tired. O ya I did not lower the guard.
I've used a band saw for 30 years. Never a problem, till now.
Dan J.
many injuries happen in a split second
Almost everyone I know who has been injured on the bandsaw or table saw simply moved a hand into the blade with a moment of inattention. maybe they were clearing away debri, or reaching past the blade for something. that's why I try to stay scared of it. I have a rule, stare at the blade. I hope that buy staring at the blade I am constantly aware of where it is and where my hands are. It's worked so far but all it takes is a split second.
Re: Hook tooth vs Skip Tooth
Keith Tompkins
Doc, a hook-tooth blade has about a 10 degree positive rake, while a true skip-tooth has a "0" rake. The skip tooth is far less agressive, but still cuts rapidly. I think a 3 TPI hook-tooth is too agressive for cutting bowl blanks...especially considering the change in grain direction.
I think it's just bad habits?
Steven Antonucci
A lot of folks have bad shop habits. They may get away with something 1000 times, but it's that 1001st time that gets them. I see it all of the time (and I am guilty of a few of my own, as well).
Last year, a guy put his hand into a jointer pushing a board through in a very well known woodworker's class. People may get offended by correcting this kind of stuff, but the reality is that a pushblock is sacrificial. Everything behind the pushblock is not.
Unlike a jointer, a bandsaw has two basic rules: The workpiece needs support and you don't touch the sharp spinning thing. If you forget #1, you will kink a blade in that split second, and it becomes a very expensive lesson.
Rule #2 is really really easy. NEVER, EVER, have your hand moving towards the front of the blade. It's the only way it can cut you, so find a way to never get cut. I use a sled on my tablesaw so my hands are not near the blade.
All bandsaw injuries are user error. It is probably one of the most misused tools in the shop, but completely avoidable. Unlike the lathe, where natural issues can occur like a ring shake, I've listened to lots of excuses about what went wrong and it always boils down to moving one's hand into the thing that cuts wood.
Do beginner bandsaw classes exist? Not that I've seen...
Steve
Re: I wish you would tell how. *LINK*
Keith Tompkins
Keith, here is a link to my bandsaw article. I hope this helps someone avoid an accident!
http://www.keithptompkins.com/storage/bandsawsafety.pdf
Re: I think it's just bad habits?
Keith Tompkins
Hi Steve, You are correct on all counts. I added the link to my article as well, hoping it will help. Yes, during all my bowl-turning classes, I teach bandsaw safety 101! I won't let ANYONE use the bandsaw without proper instruction beforehand, then I watch them! It amazes me when I watch people use either a table-saw, jointer, or the bandsaw; THINK and PLAN each cut, place your hand BEHIND the blade's cutting edge, where it cannot possibly cut you, and pull the work through the blade, rather than push. Some operations, such as cutting off a too-long tenon are disasters waiting to happen! Accidents on the bandsaw are avoidable...like Steve says, you must place your hand in front of the blade in order for it to cut you!
Keith Tompkins
Thanks Don
Tony - Memphis
That's something that I picked up along the way - always ask yourself where your hand/fingers are going to go when the tool spits the wood out away from you. I ask myself that before every cut.
It amazes me how many people don't even follow the basics like eye/lung/ear protection - those are pretty obvious. It surprise me how many people go out and buy a tool and assume they know how to use it even thought they have no experience. I took Woodworking 101 and 102 at a continuing ed. program here in town (thank you Mr. Ron Day!). Safety was a big part of the class as was how to use each tool. Great class. Even after all that, one of my fellow students failed to follow through on a TS rip and the board was slung back at him - clipped his arm - kept going at least twenty feet and took ou the side of a dresser a woodworking 103 student was building. The guy wasn't hurt bad (there was blood) and it was a good lesson to all of us. He didn't come back. I remember the nod of approval after I completed a rip once time and started to reach for the piece, but then stopped myself and waited for the blade to stop. I looked up and he was watching - that's when I got the nod.
Anyway, be safe folks! I try my darndest.
Tony
Coyne
It is always good for us to read the thoughts and tips that woodturners are so kind to share. I have always felt that my table saw and my jointer were the real finger eaters, and have felt comfortably safe (read that careless) with my bandsaw. I have read and will reread KT's excellent article, and the time spent today may well save me pain, expense, and disability. Thank you all.
Dick Hines
I have a Jet bandsaw with a 4TPI blade and I very seldem us it. If I need the cut something I feel safer cutting it with my chain saw. If what ever i need cutting is not FLAT I use the chain saw
matt overton
My favorite bandsaw gadget is Carter's log sled. I bought it with a gift certificate, hoping it would work half as well as it appeared. It works twice as well. Gets a flat on a log in no time and forces your hands out of the dangerzone for a supported -- unsupported cut. I use this instead of the chainsaw for splitting short logs now. It can also cut short dimensional boards and veneers. It can easily be duplicated very cheaply in the shop. And thank you Ed Moore for reminding us all.... Respect the bandsaw.
Thanks, all...
GaryG in MD
for your good comments.
I'm glad that my post generated this level of interest.
It was my intention to continue the tradition of keeping the dangers of this tool in everyone's mind with the hope of preventing another accident.
We'll never know, of course, but that's fine... it's the thought that counts.
The person in question has over 40 years experience, and he knows that he did wrong. He was too embarrassed to get into details but said he knows better. It was one of those classic incidents with being tired and a moment of inattention.
So my follow-up is:
If you think you're tired, you're already too tired. Stop immediately and pack it up for the day! You'll be able to do a much better job tomorrow with two good hands.
...Gary
Re: Thanks, all...
ken ward
I have worked with and around more tools than I care to remember and see most hurt by not paying attention.With the BS a lot of folks take it for granted when they just want to cut a quick piece off or something of that nature.I NEVER get near the blade with my fingers,I always use a push stick,a lot of people think the push stick is just for table saws,WRONG,there for anything that has a blade.If you just pay attention and take your time.you should be able to leave the shop with all parts intact.
Rule 1-sharp spinny thing here, fingers there
