Air cleaner
Air cleaner
Air cleaner
Don in Central Illinois
Lost out on bidding for an air cleaner for the shop. Thinking of building my own, but need some help. Does anyone know of plans for one? I know many of you are San Jose, so I may post this next week also.
Re: Air cleaner
Re: Air cleaner
Don I tried a quick quick google search and found a lot of stuff. Didn't look at it but there might be something. Try doing a search for this "homemade air cleaner woodworking"
Re: Air cleaner
Re: Air cleaner
Doh! I didn't even think of google. Just a few more days until your retirement. I love mine.
Re: Air cleaner
Re: Air cleaner
Neil Longhenry
Don, I got a free blower motor from a Heating/AC company. They always have some laying around.
I built a box around it. Sized the box for the Jet air filters. Wired up 2 speeds with switch on outside of box. Then ran a wire to a wall switch. Works real good.
Re: Air cleaner
Joe Fleming
Re: Air cleaner
Joe Fleming
Something as simple as a box fan with furnace filters on the input side. Box fans, however, don't really move a lot of air. I went to an HVAC installer and asked if I could have the fan out of an old furnace that they had removed. They gave it to me for free.
Re: Air cleaner
Re: Air cleaner (homemade)
John Kaner
Don,
Years ago, built one before I got the Jet Air Cleaner. Pictures lost on old computer. Basically a well sealed box. Seal the wood before glue-up and use corner blocks. I used 3/4" plywood and thus was able to add wheels and use the top. I made slots on outside for a washable furnace filter. The filter is held tightly to the box. The fan is usually free from a HVAC dealer/repair. Most have several speeds. You use a combination of two wires. Decal on housing. I also filter outlet air.
There are some that are a tower. They use several filters.
I gifted my unit years ago. It worked very well and I had two extra washable filters that I switch out. Bought filters at Wally World. They were on clearance, odd size...
Hope this helps. John K.
Re: Air cleaner
(Message Deleted by Poster)
Re: Air cleaner
Re: DIY Air cleaner (homemade)
Carol
Made one years ago.
Simple. Rectangular box to house a furnace fan on a interior partition board. Make sure all the intake air goes through the filters. No leaks and no by-passing the fan. Used 2 standard furnace filters on the intake and one on the exhaust. Rotated filters. When the first intake was dust colored, it got shook out. When that didn't work any longer, it got tossed. The number 2 intake migrated to the number one slot. The exhaust filter migrated to the # 2 intake, and a new one replaced the exhaust. Worked great for years. Sold it when I left California. Have since acquired a 'found' JDS.
Re: Air cleaner
Gil Jones
Don,
I could not get the MS Word file to upload to this forum as it is 188kb (too big).
So, if you want the plan to build an air cleaner just email me and I'll email it back to you or anyone else.
gbjones1@windstream.net
Gil
Re: Air cleaner
Re: Air cleaner
I built one years ago and am still using it. Got a free furnace filter as mentioned above. Be sure you get a 120 volt one unless you want a 220 one. Have them show you how to wire it. Some are multiple speeds.
Made a box with a solid top and bottom. The other four sides were open and have slots for filters. Similar to Carol, I have three inlet filters and one outlet. Coordinate your opening size with available filters. Use a common size so you can buy replacements later. I used the same set for a year or more.
I put a ribbon on the front to help me judge the air speed and tell when the filters need cleaning.
I am considering making another one for the opposite corner of the shop to help create a circular air flow.
Re: Air cleaner
Re: Air cleaner
Thanks all. As soon as I get the porches dobe, I can start on this.
