Veritas - Innovation in Tools
Lubricated Vacuum pumps
Nick Todd
What is the benifit of a lubricated vacuum pump over a vacuum pump that is not lubricated(oil less)? Does it have more to do with the pump original purpose. I am assuming a lubricated pump is designed to run for an extended time period.
Nick
Re: Lubricated Vacuum pumps
Dave Paine
Typical benefits of lubricated pumps/compressors is less noise and longer run time before maintenance due to less wear with lubrication.
I expect pump design determines whether intended for extended run vs short run, whether lubricated or not.
I have a Gast 0522 pump which is lubricated.
I have the same pump.
Jorge
I have a Robinaire, forgot what number, it is lubricated, but it is not meant for continuous duty. IT was made to retrieve freon from cooling systems, so it overheats in 15-20 minutes.
Very powerful, 6 cubic feet per minute, got it cheap.
Samo
Robinaire 15600 bought rebuilt.
Pump's made to evacuate a/c systems so a continuous airflow tends to pick up oil and exhaust it in a fine mist. Makes a mess. Solved the issue by adapting a oil coalescing filter
No more oil mist.
Does tend to run warm, but I rarely run it for more than 10 minutes to clean up the bottom of a turning. Solved the heat issue with a little 4" muffin fan blowing on the casing. Guess the internal fan could be better, eh?
Re: Samo
Jorge
Hi Mark,
Thanks for the heads up. I do the same, After acquiring the Powermatic, the Nova became a dedicated foot cleaning station. Like you said it only takes 5-10 minutes to do the job, my problem is that I trend to work in batches of 4, 6 or more similar pieces at one go, then I clean one and have to do something else for a while.
I'll add a fan. :o)
Re: Samo
Jorge
Mark,
What are the specs for that filter?
I did ask in the local parts shop and got a blank stare...
Thank you!
Just saying lubricated is not a good description
Keith Newton
I finally looked up the Gast 0522 pump, which is a rotary vane type. I have one of those a lot bigger than that one, and it is so loud, i just can't stand to use it.
Two others that I do use, are really quiet, and are merely two pistons, in a standard pump with oil in the crank case. They hardly ever need oil added, and don't' send it up in the air with the noise like the rotary vane type. If someone came into my shop and ask for mine, I would give it to them for free, just to get rid of it.
I have on occasion used my Rolair air compressor for vacuum bagging. All you have to do, is open the tank drain, and enough plumbing on the intake side to get from 3/4" NPT to 3/8" hose barb, and presto, you have a quiet high volume, 28" Hg vacuum pump. Almost any old pump will make one.
Re: Just saying lubricated is not a good descripti
Nick Todd
Keith,
My description may not had been the best, But I got an answer/opinion that I wanted.
With my model(522) and the stock muffler/filter, the noise is more than reasonable. The oilier(lubrication) may reduce noise further. Like the other posters, I typically finish several pieces in succession.
There are several models that are identical to mine in design except for the oilier. I was just wondering what the benefits of the oilier was.
