This is an old piece of mine, but new to you *LINK*
Keith Newton
I don't recall ever sharing this piece here. It would probably be at least 25 years old.
I turned it outboard on a PM 45, I think I mounted a big chain sprocket on the inboard faceplate, then drove that with a gear-motor from a conveyer system, so it would turn at about 1 rpm.
Then I made a full length fence - bed to run my makita 6' power-plane on, as I trued it up.
The wood is QS Wenge. The tapered staves were shaped on one side with a half-round on one edge, and flute on the other, so they fit together at any angle like a hinge. I used epoxy for the adhesive.
I like doing really clean simple shapes. So I'm satisfied with the outcome there. I'll leave it to you to figure out how to make the cuts on each of those parts, where the angle constantly changes as the cuts progress around the piece. The trickiest part was putting it all together in a way that the solid wood could still move, without self-destructing at some point later on.
The brass pivot hinges are all different due to the changing diameter at each location.
The elliptical glass is 3/4" thick with a 1" bevel, x ~ 24" x 48" and I think I recall making the cone about 30º. I thought I would share that, if any of you want to do a knock off. I didn't' make a pattern, so don't ask for one. he he
http://www.flickr.com/photos/7391658@N03/7330658150/in/photostream/
Re: This is an old piece of mine, but new to you *LINK*
Awesome!
Don Orr
Mind boggling but awesome.
