Turning Small - How To & With What
charlie belden
Posted this in response to this question asked in an earlier thread but here it is again.
The procedure I use is the reverse of what you'd normally do. Rather than turning the outside profile first, turn the INSIDE profile first while there's still plenty of wood behind the cut - actually more like a scrape.
With the INSIDE profile done, you can measure how far down the dowel the bottom of the inside profile is - and sneak up on it when turning the OUTSIDE profile (This'll make more sense when you look at this How To Illustration
The tools I use are pretty simple
- an 1/8th inch parting tool made from an old reciprocating saw blade with masking tape "handle"
- a 1/4" bench chisel used like you'd use a bedan or skew
- a 3/16" rounded end insert tool
Just tried a little hollow form that turned out pretty nice
It was hollowed with this home made tool that's easy to make
Here are some detail shots - not pretty - but it works
When doing the OUTSIDE - you only need to turn the details petty close to what you want. The rest you just cut/scrape roughly for the basic shape. Then you sand to the final shape you're after.
What turning small really requires is delicate tool control. From my jewelry making days doing lost wax cast pieces, if you can get contact between the piece, the fingers holding the tool and the fingers holding or touvhing the piece - they all work together pretty precisely.
Questions, comments and suggestions welcomed. These mini pieces are fun as hell to turn!
Re: Turning Small - How To & With What
Neil Longhenry
Thanks for the posting Charlie. I missed the earlier one. Much appreciated. - Neil
