Aesthetics At Different Scales?
charlie belden
Within a range of "normal sized" turnings, a set of aesthetics have developed for differnt FORMS of turning - hollow forms, finials, boxes, plates, bowls, vases, etc.. And a general set of "rules" have been developed that will result in a pleasing piece for each of the general FORMS, at least providiing an envelope for the proportions - height to width, foot size, neck size, where "shoulders" should best be located, etc.. And these "rules" generally do produce an aesthetically pleasing piece - IF the piece is similar to one of the "regular" forms.
For less often turned, or never before turned forms - unfamiliar forms, the aesthetics are developed by the turners, Escoulens' "golf club driver", Gary Fisher's eccentric works, now Barbara Dill's multi axes pieces.
I've been doing a LOT of miniatures over the last several days. Miniatures are usually merely replicas of full sized pieces, scaled way down. But, at a small enough scale, the wood will not let you go any smaller, there just isn't enough strength left, or due to the limitations of the fine motor skills of most humans.
It's at and below these threshold of scale that things can get pretty interesting. And when you go small enough, there are few if any "rules" to follow. As a result, there's plenty of room to play in
If you just want to explore forms and proportions, a poplar dowel is a great blank to start with. But if you want to add the color and grain of the wood,choosing the right wood can be the difference between a really nice piece - and merely a pleasing little piece. Fruitwood, cherry, plum, apricot or pair - the heartwood - works well. These woods arre pretty strong,the grain is pretty fine and there are color variations - perfect for turning thin and delicate - relatively speaking, given the scale of miniatures.
Back to the aesthetics thing. I'm finding that, because of their petiteness, you look at miniatures differently. You don't pick them up and look at them - unless you're willing to crawl around on the floor to find them when you drop them. They sit still and YOU move around them. What you perceive and experience is quite different from "normal size" pieces. Its the side profile and the top view that registers in your mind's eye, NOT the total piece. There's no HEFT or LIGHTNESS, the pieces only a half gram or less. And if there's figure in the wood, the piece is examined as if it were a gem rather than a turning - you look VERY closely and see tiny details you probably wouldn't notice in a larger "normal sized" piece.
Oddly, what would seem thick and massive at "normal size" may look just fine at 1/12th scale or smaller.
Here are some shots of FOUR MORE. At larger sizes, each might look THICK. But at this small size, I think they look "right. Ok, so the bead at the foot of some could be a little finer - but . . .
Comments, critieques, suggestions welcomed.
Re: Aesthetics At Different Scales?
How are you making these?
Hi Charlie,
Interesting theory about the aesthetics changing at tiny scale. I guess I'll have to make a few and see if I get a better sense of what you're saying. I'm just wondering if you have any tips on how to make these minis. They look like side grain, but you mentioned using a piece of dowel. Do you need mini tools, too? I have a set of really mini tools that I made from some Irish nails. I imagine those would work, especially for the finest details.
Don Leydens
Re: How are you making these?
Don Leydens
Hi Charlie! Your pieces look great. Thanks for the info on esthetics at different scales also. Like Ellis, it really made me think. I've made some bowls and plates about the same size as the ones you posted and it was quite fun.
Ellis, I'm betting Charlie has some cool tools he's developed for these, but I tried just using some tools I had and they worked quite well. A Spindle Master worked
well and came in quite handy with it's sharp point. I even put some texturing around the rims with a Pounce Tool (see link below, if you're interested). That fine texturing usually shocks the heck out of people. I use it sort of like a very mini Sorby texturing tool. Be careful though, a light touch will help keep the pounce tool in one piece.
Keep up the good work Charlie!
http://vimeo.com/12618233
see:Turning Small - How To & With What
charlie belden
I've posted - again - an illustrated step by step of the method I used to turn these mini pieces, along with shots of the tools. It's NOT HARD to turn small - if you have a steady hand.
If an old bayonet saw blade with the teeth ground off to use as a 1/8" parting tool is a special cool tool . . .
If a 1/4" steel rod crudely ground a bit for hollowing is a cool tool . . .
Honest, you don't need any "special tools" to turn small. Good vision and fine motor skills are far more important.
