Finishing on the lathe
Paul Zerjay
I spray lacquer as a finish on most everything I turn. Problem is when I spray, the lathe is no longer usable for the time it takes for several coats of lacquer to be cured enough to set aside to cure completely. I am looking for a cheap way to spin smaller, less heavy turnings at an rpm of around 50. An old record player comes to mind. They spin at 33-1/3, & 45 right? Couldn't a guy double stick tape a lightweight turning to the turn-table and spray like that? Anyone ever try something like this?
Re: Finishing on the lathe
barry rockwell
Barry Rockwell
It certainly won't spin at 50 rpm, but for years I have used barbeque rotisserie motors to finish different projects, even before I became a woodturner. They will run very efficiently, for hours on end, and are very easy to find, cheap. You might think about trying one, and the investment is minimal.
Darryl
Paul, I used to use an old motor from a rotisserie when I made and wrapped fishing poles. I would think that would work for what you are after. You would need to rig up something to attach it to your face plate. Darryl
Re: Too slow
Paul Zerjay
I have a rotisserie and I feel it is too slow for spraying. I try to spray a good "wet" coat when I spray, and am comfortable with a speed of 50 or so RPM's. I think I would get runs spraying a turning that is spinning that slow. Once it is sprayed...it would be fine I believe.
Re: Too slow
D. Hansen
I agree but if you need to rig up some sort of belt and pulley arrangement anyway you could use a differential sizing to give you the speed you are looking for.
Re: Too slow
Paul Zerjay
I agree. But even though I am mechanically inclined, that sounds a whole lot harder than getting a $10 record player off Craigs List and seeing if it'll work.
Record Player - ??? *LINK*
Doc Green
I don't think the record player will work if you intend to mount it so that the rotational axis is horizontal. Reason is that the available torque is very small. On cheap turntables, the motor spindle makes contact with a rubber wheel that in turn makes contact with the inside of the platter. The diameter of the drive spindle is very small, maybe only 1/16" or so, and it can very easily slip and fail to transmit the torque to the platter.
The problem will arise if the turning is out of balance (due to variations in wood density) or if the turning is not exactly centered on the platter.
Another approach would be to purchase a Gear Motor that rotates at 100 RPM or so and use a drive pulley combination to give the RPM you want. Surplus gear motors can be obtained from The Surplus Center for less than $10.
Sounds like a fun project. I may have to build one! ~Doc
http://www.surpluscenter.com/electric.asp
Electric Motors at The Surplus Center
