To Quote Gene Autry (who?!)
charlie belden
"I'm back in the saddle again."
After a three month long hiatus due to a stuck chuck and several micro crisis and mini panics, I got the chuck unstuck and got back to turning again.
A new pseudo adoptee, almost nine, discovered SHE needed a Magic Wand - and I was to make it for her : )
Took a while to get the rust off by skew turning skills. After it was turned I needed to turn something other than another wand. With plenty of small pieces of all sorts of wood, none big enough for a Real Piece, and since small spindle turning is easy to pick up - some small bowls seemed like a good idea. Little wood needed, a catch on a 1 inch diameter piece ain't traumatic, and if I blow it - very little precious wood lost.
Now if turning is the Crack Cocaine of woodworking, turning little bowls must be whatever is quicker - twenty minutes start to finish - literally all the way to polishing.
You've got to try turning small stuff. Great for prototyping - and the resulting pieces don't take up much shelf space at all.
(the smallest piece is sitting on a dime.
The depth of field at this scale is kind of limited so here's two shots that show the profiles.
Try it - you'll like it!
