A55 Smoothing Plane
OT Window air conditioners
Paul Zerjay
I forgot to mention I had an appliance repairman over to my house for another issue and I asked him about my window unit that wasn't working properly. It seems my condensing coil on the outside of the unit was the culprit. The unit has a metal housing with punched-out vent holes for the fan to blow air across the coil. These vents let all the cottonwood fuzz-balls and anything else that floats in the air, come into the back of the unit and attach themselves to the coil, therefore blocking the airflow across the coil. A good blast of compressed air did the trick. My shop has been comfortable while the temps outside have been soaring. Thanks to everyone who replied, and I do have a plan for a pre-filter on the front of the unit.
Re: OT Window air conditioners
Bill Howatt
I used to work in a research environment with a guy and I was continually surprised by how much inoperable equipment he was able to fix just with a good cleaning. Granted, in many cases it was a lot more than just a blast of air.
Bill
Me too!
Tony - memphis
We had the ac man out Friday to top us off. He added a stop leak product to see if that would help. He said he does the job 75% of the time. Something he did worked. Our system usually runs no stop at the mid 90's, but it was actually cutting off now and then over the weekend. I pulled my shop unit our and did the annual coil cleaning. Its a pain, but it does make a big difference. My coils get really dirty. Not sure why, but they do (not sure where all that stuff comes from!). Wish there was a way to hit them from outside. Its a messy job. I keep a thermometer in the output and it was measuring 52° or so. My shop is 16x20x10. The unit ran quite a bit this weekend - mid 90's here. Kept things comfy though. I turn it way up when I'm not out there. I also keep a fan in front of it when I'm working to better distribute the air.
Tony
