Lami Wood
gary mcgrath
I lost a sale on this when the customer asked the type of wood, and I responded "plywood". She must have been expecting something more exotic. Now I say "Lami" Wood and sales are brisk! Any other suggestions?
Lami Wood
gary mcgrath
I would just say birch...
Steven Antonucci
If you stock is coming from the same place we get ours, that's an acceptable answer...
It is dyed birch with glue. Segemented, of sorts, eh?
Steve
Re: Lami Wood
mjonesrdg
I would call it "Handsome"!
Hasn't Hurt Stephen Gleasnor *LINK*
You can't please everyone. I think simply changing the wording is a good idea. Just call it laminated wood and let it be.
http://www.stephengleasner.com/Site/Stephen%20Gleasner%20Artist.html
A question, Gary
Charles Yawn
When you glue the plywood together, how do you deal with the outer layer(s) on each board? When I made a bowl with plywood, the outer or top layer of the plywood glued together created a section that was much thicker than the other layers. I'm guessing that I will have to slice off that veneer before the glue-up.
Charles
Re: A question, Gary
gary mcgrath
I haven't normally been too concerned with that prblem, Charles. Most cheap plywood I've used has pretty thin outer veneers. In your case, run the boards thru a drum sander (if you have one), which will remove the 'top' skin. Here's another in process with construction grade plywood:
