angle drills O/T
angle drills O/T
angle drills O/T
Darryl
Just had one of my close quarter drills give up. It is in the switch not the bearings. I know from experience the switch will run about $26.00 but for $32 I can get a cheeeepy Neiko replacement. My question is whether I could get a simple radio shack rheostat and mount it so the knob protrudes through the case in place of the variable speed switch that is in the drill. I think there would probably be room since I could also remove the reversing module at the same time. Problem is that I am not that knowledgeable about switches and stuff. I do have the Milwaukee/Souix wiring diagrams and they seems to be the same. One wire comes into the field of the armature from the wall plug the other goes through the switch and reversing thingy and to the other field. From the switch both brushes are fed. I realize I could not control the speed with the trigger switch but that might be easier than holding the trigger down anyway . Any ideas??
Re: angle drills O/T
It can probably be fixed.
Scott Crumpton
You can't use a simple rheostat, the speed control is much more complicated than that. However, all may not be lost and Radio Shack may be your answer. Get some of what used to be called "TV tuner cleaner" at RS. The stuff I have is called Jiffy Bath, made by GC Electronics. Don't know if they still make it, but I'll bet they make something similar. It's basically a Petro based cleaner with some silicone in it. Take your drill apart, pull the trigger assembly up where you can get at it and flush it out with several sprays of this stuff. The speed control has several small contact points and a rheostat in it that get loaded up with dust and quit working. As long as nothing mechanical is broken this should fix it. Let all the liquid evaporate before applying power. It worked for me on my Neiko. And while you have the drill apart, blow out the dust and clean out all the old grease. Then load it up with some good lithium grease and some light oil on the bearings. Normal maintenance for these drills is to do this every now and then, before the bearings seize.
---Scott.
