My process for making boxes.
Steven Antonucci
In reading the threads below, I thought it might be helpful to describe how I make a box (with any shape).
1.) Start between centers and rough to round.
2.) Turn accurate tenons on either end and part into two pieces.
3.) Grip the section that will be the top by the tenon and hollow the lid.
4.) Grip the section that will be the bottom and hollow the bottom.
5.) Turn an accurate tenon on the bottom that fits the lid. If you make it too small, you can compensate with a tissue/paper towel.
6.) Jam the lid on and finish the outside.
7.) Remove lid and part off the bottom of the box.
8.) Turn a small tenon on the remaining stub in the chuck and jam the bottom over it.
9.) Finish turn the bottom of the box.
If you follow this procedure, you can work with each surface to finish one time and keep the grain orientation perfect. It overcomes needing any special extras other than the chuck and possibly a paper towel.
I follow a similar work sequence when threading a box, except in steps 4-5-6 when I cut threads and screw the lid on instead of jamming it.
Hope this helps you budding box makers.
Steve
