Split ring holding of lids
Mike Stafford
Mike Stafford
I decided to answer Don's question outside of John Lucas's thread and hopefully John will chime in to offer his insights.
Ed Moore taught this method in his box class to hold inset lids like the one seen on John's box.
Basically you mount a scrap block of wood between centers. This scrap block must be larger than the diameter of the lid you wish to hold. Turn a spigot/tenon on each end. Slice 1/2-3/4" off of one end. Remove the block from the chuck.
Mount the slice in the chuck and turn out the center creating a ring with a hole all the way through making sure the hole that is left is slightly larger than the lid you wish to hold. I like to create an internal dovetail into which the lid I wish to turn will fit.
Take the ring out of the chuck and head to the bandsaw. Cut through one side of the ring.
Now when you put the lid blank inside the split ring and mount the ring in the chuck the lid blank will be held by the split ring as you tighten the chuck. Even if the split ring splits into two pieces it can still do its job but it is slightly more tedious to mount.
I save my split rings in hopes that when I next turn a stopper fit box lid I will already have a split ring to accommodate the lid. It almost never works that way unless you are doing production turning but one can always hope..... ;)
If you don't want to do it that way you can turn a recess in a scrap block and jam fit the lid into the recess. Just make sure you have a hole drilled through the scrap block so you can tap the jammed lid out of the waste block. I have found I split less lids using the split ring method.
I have pictures somewhere of the split ring at work but I have not been able to find them.
I hope this makes sense.
Take the
Re: Split ring holding of lids
Re: Split ring holding of lids *LINK*
I did this lid the simple way which I'll explain. I also use a version of the split ring but I call it a collet chuck.
To turn this lid I simply turned it so the top of the lid was toward the headstock. I turned the bottom to fit the box and decorated that. Then I turned the top side of the lid and roughed out the handle. I did the chatterwork on the top of the lid. Then I turned the knob leaving a small tenon on top slightly smaller than the top knob detail. Now I sanded everything and applied a coat of black dye. It was water based which raised the grain. I let it dry and sanded it lightly with 600 grit paper. Then applied 2 more coats. I applied a very thin coat of lacquer. Then I steel wooled it slightly until I got the color I wanted. I then used the toe of the skew to finish the top of the knob leaving a very small tit right in the center that I cut until the knob fell off. This little bump or tit is there so if the wood tries to pull out as I part it off with the skew I can carve it away and get below the tearout. then I just sand by hand and apply more dye and then finish.
I use 2 other methods to do lids. If the lip of the lid is long enough I use a jam chuck. I take a scrap block and turn an opening that is a force fit for the lid. Then I turn most of the lid with the tailstock in place removing it for just the last little bit of turning. this is the method I use most often because I can often use the same piece of wood that I chucked up for the box or the scrap left over from the box as my jam chuck. If my wood was too small to do that, like in this box, then I simply grab a scrap out of my scrap pile.
The Collet chuck method is very similar to what Mike teaches but I make 2 cuts with the bandsaw which creates 4 jaws. I use a hose clamp to squeeze the jaws together. I have also made very short collet chucks that work by being squeezed by your metal 4 jaw chuck.
Another method I like is to turn a tenon on both ends of the box blank. Then I part the box at the lid joint. I rough out the box and turn the inside. I mount the lid in the chuck and turn the underside and make it a very snug fit in the box. Then I mount the two together and turn the lid top along with the outside of the box. I remove the lid and take off just a hair of the inside of the box to make the kind of fit I want on the lid.
There are lots of other ways to turn a box or lid parts. Doc Green has an excellent book on chucking methods. I highly recommend it.
http://www.amazon.com/Fixtures-Chucks-Woodturning-Everything-Secure/dp/1565235193/ref=sr_1_1?s=books&ie=UTF8&qid=1337628516&sr=1-1
