The other day, my mother in law had a dying maple cut, so I loaded up the truck with some of the bigger pieces after splitting the smaller stuff for firewood (yeah, a little wood gloat)
I cut it into some smaller bowl blanks and rough turned them. I put all of the wood in a plastic bag to keep it moist until I could get back to it last night. When I went into the garage, there were carpenter ants everywhere. They were not in the log, as all of the wood was still bagged and sealed, but they appeared to be attracted to the large volume of shavings.
Has anyone ever seen this? I actually had to sweep up last night.
I've seen rings of insects around the sapwood of a fresh cut log, drinking up the sap. But not drawing in carpenter ants unless they were already around. Think the ants were already near your shop? Might be worth a check.
Carpenter ants (Camponotus sp.) generally do not nest in wood that is not already dead and/or rotting. It sounds like you brought in freshly-cut maple wood, and it is not likely that they came in on the wood (you certainly would have encountered the ants prior to first moving the wood), unless of course there was a rotten and infested section in of one or more of the pieces you bagged. A surprisingly huge number of ants can fit into a relatively small space....
Jamie may not be too far-off - the ants may be attracted to the odor of the fresh sap in the phloem just under the bark. Remove a chunk of fresh bark and sapwood and place it in an area on the floor in which there are currently no ants - if the swarm to the fresh piece, you know this might be the reason why they're in your garage! If there were many ants already present in your garage area to become attracted, or from adjacent areas outside (within 30 to 50 feet or more), it would be good to follow the ants to discover their source and then stand down from turning for a while and become an exterminator.
Normally, carpenter ants need wood that is fairly moist and not too dry; and they don't often invade living trees.
I just checked the garage and the outside where I had originally chainsawed the logs, and there are no more ants. Actually, I assume that the ants followed the shavings down the hole I dump them in, but there aren't any in the shop (nor were they present beforehand).
I truly believe that they were lazy ants looking for a free meal after I did all of the work getting the wood into smaller digestable chunks. The wood was sopping wet as evidenced by the face-full of sap I got every time I walked past the spinning blank. Must have been like a big party for those ants...
Discussed the perfect shop last night. The floor would be a raised steel mesh in a small room with a light and a stand for my tormek. Shavings would fall directly into a hopper below me. I would probably magnetize it to prevent tools from falling into the abyss.
We have a few houses here in Juneau that get reconstructed because the carpenter ants have moved in and setup housekeeping in the framing of the house - usually walls. They love styrofoam insulation because it tunnels so easily.
This species of insect does not eat the wood as a termite does, but uses it for creating house and home.
Do take an effort to assure they did not have a short comute from inside the walls.
I turn lots of sugar maple with no ants. Hard to believe they come seeking out shavings. My guess is they were around before the maple arrived, unless you didn't check out the stock really well and they really were in the maple before turning. My take on carpenters and maple is they like the sapwood. Evil carpenter ants!!!!
It is not surprising that there are carpenter ants associated with large trees. There are over 1,000 species of carpenter ants, and their living requirements vary from fully-rotted, wet to moist wood, to simple voids or pockets within the wood or under the bark. Some species can convert a simple void into a "nest" (such places are termed 'domatia') where the ants can find protection and establish a place to lay eggs, raise pupae, and expand the colony. Normally carpenter ants do not tunnel or burrow through "sound" wood, but prefer decaying or otherwise rotting wood in which to construct their galleries and undergo reproduction. Some carpenter ants are also attracted to certain plant species that actually have small glands (most often on or near the petioles of the plant's leaves; = 'extrafloral nectaries') which secrete a sugar-water solution to feed the carpenter ants; the presence of the ants on the nectary-containing plants provide protection from other insects that could damage the plants. Do you actually find ant "nests" in non-rotted solid wood? This would be quite unusual.
You laugh but my friend Brad Sells does a lot of his chainsaw roughouts near an opening in the floor. Below that there sits a trailer most of the time already hooked to his truck. When he's done roughing what hasn't already been tossed down the hole gets swept into it and fall in the trailer. He also has a hydraulic chainsaw with the huge compressor off of a navy ship in the basement. this makes it very fast for him to get things roughed out so he can start his finish carving with the angle grinders.
Yes, there are a few times that I can recall finding their galleries in heartwood of living trees, absent of decay, but not without having lost a limb which provided entry. Those trees were things with high resistance to decay, like catalpa, black locust, cypress, walnut etc. of course, this would be in green wood.
They are fascinating social insects to me, a budding macro photographer. I have gotten some pretty interesting shots of them over the last few years, such as tending a flock of aphids, to stealing a stink-bug paralyzed by a sand wasp which laid it aside while she enlarged her tunnel.
The log was cut and down, but the tree was still solid. The interior had flooded, and all of the ants were frozen inside their tunnels, waiting for spring... or the heat of my shop.
