THE WOODRAT IS BACK!
my mirror supplier changes sizes
I didn't even think to measure the new mirrors. They are now an odd size, 4.093". That's not exactly metric and certainly not inches. Oh well I'll have to change my go/nogo gauge. Had to put a mirror blank back on the lathe backwards and open up the opening a little more.
Re: my mirror supplier changes sizes
Randy Gleckler
Well that's no fun to discover. Good thing you've done 1 or 2 of them and know how to make adjustments. :-D
Galen Vetterick
Just great! Now if I order a mirror from you I'll get charged for a retooling charge plus more for the basic mirror since it is a full 0.093" larger. :D
Philip Duffy
could you share the name of your supplier? Thanks, Phil
Mike Stafford
As Americans get larger....
Mike Stafford
in girth it only follows that mirrors will also have to grow to accommodate their expanding image...... :D
Barry L Elder
Probably your mirror supplier changed mirror suppliers! :D
Hard to get any sympathy for this group!!
Steve Criscenzo
Could be just bad quality control for this batch. Be sure to check the next batch
Steven Antonucci
Their diamond wheels have worn .00465"
I buy from TRipar Inc. It's a wholesale supplier of business display merchandise. They just happen to carry round mirrors to put things on. You need a tax no and minimum purchase is $120. I do have a supplier listed on my home computer that will sell small quantities of mirrors at reasonable prices. If you want it I'll try to remember to look it up tonight.
I measured them again last night and they are 101mm or close. What an odd size. doesn't matter as long as I know and can correct for it.
Jesper, Denmark
Jesper, Denmark
John, the two dimensions are not the same. 101 mm is just a tad under 4 inches (3.976 inches). The 4.093 is close enough to 104 mm to make sense (103.962 mm).
The 101 is likely to be intended to be 4 inches with some tolerance, but why the 104 mm??
Using a standard caliper with a vernier scale, 0.1 mm is about as accurate as you get.
Just for the sake of completeness, 1 inch is 25.4 mm.
I'm going to have to check either my mirrors or my ruler. I know the one I read was exactly 101. I used vernier calipers to measure the mirror that went in the Desk Mirror which was a different piece of glass. I'll measure several tonight and see. That would suck if they are all a little different. I'd have to put labels on each piece of glass to make sure it stays with the wood during the production stage.
