OT window AC units
Paul Zerjay
How many of you cool your shop with a window Air Conditioning unit? Anyone have any special tricks for keeping one operating for more than a couple summers in such a dusty environment?
OT window AC units
Paul Zerjay
Re: OT window AC units
I just bought a cheapie unit and it's been running for 5 years now. I clean the filter on the front regularly but other than that haven't done a thing. Now granted I'm in Tennessee and don't have to use it all that much. I use it mostly to knock the humidity down. I run several fans in the shop because the air movement seems to help as much or more than the air conditioner.
Philip Morris
I fabricated a pre-filter, based on a cut-to-size, washable, electrostatic HVAC filter, which I attached over the inlet vent with double-faced velcro. It was simple to remove and wash and kept most of the dust off the coils. Below is a link to the one I used.
Jim Breeden
I have a mini-split with heat pump, and made a filter frame like Philip, to keep as must dust out of the system as possible. Works great.
Mike Mills
I just drape a couple of paper towels over it and give it a spray (light) of water. At the end of the day just toss. Doesn't seem to stop much air flow, if any at all.
Bernie Weishapl
I just bought a cheap Wally World unit. I cut a pre-filter for it and it has been running 6 yrs now.
Paul Zerjay
Yeah well this bonehead didn't think of putting a pre-filter in front so now I have crap all inside the fins. I'll pull it out and see if I can clean it without damaging the coils too bad and reinstall with a pre-filter...
Don Evans
You should be able to "backwash" the coils with water hose. Hope you have fins on the coil instead of the tinsel looking stuff, if fins you can straighten them if any get bent. Look up a HVAC distributor in your area and swing by and get a "fin comb" and some of the coil cleaner. The cleaner will work much better than any from hardware store.
As a side note: if you need any wasp or hornet spray get some from the HVAC place also, look for Jet Force or same exact thing from CRC (blue can). This is the most deadly spray I have ever seen, hit a nest with it and they all fall straight to the ground NO stinging the person spraying before they crock. I use to buy it for my techs who worked on SAT dishes. Now retired, I still by it for myself, 6 cans to a case about $45 but worth every penny.
Don
Mini-Split is an Excellent Option
Brad Vietje
A well-made mini-split unit will provide both heating and cooling, with pretty good efficiency.
Adding more insulation and reducing drafts will save on both ends of that equation, too. If you go for a window-mounted AC box, try to put it on the shaded side of the building,if possible.
Safe spinning,
Brad Vietje
Newbury, VT
Re: Mini-Split is an Excellent Option
Ralph Lindberg
I've been planning to replace the heater with a mini-split for some time.
If you are handy you can do 90% of the install yourself. Then find a HVAC guy to do the charging (like on Criagslist) and you will still have the warranty.
There are a number of mail-order places that will sell you the system for a reasonable amount
Tony - Memphis
I do. I have a 16x20x10 shop cooled and heated by a small GE unit. It is my third unit in 14 years. The Goodman and the Freilich? gave up. This unit has been he quietest so far. I checked and they sell most all of the parts for it at the online repair parts sources. The #2 unit just needed a new fan, but I couldn't get one - neither could the repair person who was trying to honor their warranty.
I built a frame that covers the intake and I mounted a 16x20 pleated filter in this frame The filter has a small frame that goes over it and holds it on with magnets. That makes it easy to take on and of when needed. I don't leave th filter on when I close up. I have a dust collector and an air cleaner on the ceiling too. Once a season, I slide the unit out and clean it up real good. It is amazing how much stuff gets in the coils. There is no easy way top clean it without sliding it out and taking it apart. It is a chore. The shop is insulated very well and it stays very comfortable. I also run a dehumidifier. I keep the air temp pretty high when I am not working. Cools off pretty quick. Can't recall the capacities, but it is the smallest unit GE offered with heat.
Tony
