Drum Sander
Lewis Dodd
I am looking at a Grizzly 1066 drum sander,
what negatives are there other than being an import?
Drum Sander
Lewis Dodd
Re: Drum Sander
darrin hill
you can make your own for about $200...
Re: Drum Sander
Lewis Dodd
Well Darin, you certainly got my attention! Anxious to hear more! You getting pretty wet over there in Aggie Land?
Re: Drum Sander
Lewis I built a simple one that was a Drum (2x4's glued and turned) driven by my lathe with sandpaper glued to it. Then I built a sort of tilt top table to sit on the bed of the lathe. The tilt was my height adjustment. I simply had wedge that a screw pushed in and out to raise and lower one side of the table.
It worked. It was a pain in the but to push the segmented rings under it. By the time you had 20 or so rings flat on both sides your fingers were sore. I always thought I would build a motorized platen to feed the pieces through but never did. Now I have a Performax sander that I got used. It is way nicer but takes up a huge amount of space in my shop.
Re: Drum Sander
darrin hill
we griped all last year about lack of rain and now its flooding every other week...
I can get plans for one.. I didint build it, but one of our local woodturners made me one. If you're not in a hurry, i can introduce you to him if you are going to swat... he could probably tell you how to make it..
or i could give you his email...
d
Re: Drum Sander
Doug
Hi Lewis,
See this link
www.aawforum.org/vbforum/showthread.php?t=9508
for some ideas.
Doug
Re: Drum Sander
RCH
Search for thickness sanders on the web. Lots of plans. Luthiers build them up to 24" wide. I built one using an old furnace fan for power, for preparing ship modeling 'timber', that can handle up to a 12" width and >1 1/2" thickness. I used it for getting the faces parallel for a couple segmented pieces.
