Stuck Chuck Solution
charlie belden
Having modified my JET Mini VS to add a reverse function, I had to then do something to keep my chuck from spinning off when I switched to reverse. And what I did was quick and easy - but stupid - LokTite. While it did keep the chuck from spinning off whenthe lathe is reversed - it also kept it from being removed when I wanted to switch chucks or use a drive center or face plate.
Lacking a spindle lock, and having the head stock collar with two holes in it for a tommy bar, holding the head stock fixed while using a wrench to get the chuck with adapter off works - unless - the adapter is LokTited to both the chuck AND the head stock thread. I bent my knock out bar trying to use it to keep the head stock shaft from rotating while using channel locks on the adapter. To make matters worse, there's not enough space between the head stock collar and the adapter to get an open end wrench on the adpater.
What I needed was something other than a tommy bar to hold the headstock collar fixed and an open end wrench that was thinner than normal open end wrench thickness. What I needed was a bicycle shop wrench for the adapters and a tool we in the U.S. often don't even know exists - a SPANNER.
Off to the nearest bicycle shop (we have lots of bicycle shops in the SF Bay Area because there are so many places to ride and so many types of riding options - road, mountain, cyclo cross, veledrome. Natuarlly, I needed a 38+mm open end flat wrench - and they only make 36 and 40 mm. But channel locks would do - IF I could hold the head stock collar securely.
There on the wall of bike tools was THE ANSWER - a Double End Bottom Brakcer Locking Ring Hook Spanner
With the head stock secured with the spanner, the heaviest set of jaws on the chuck opened to accomodate a 1/2" steel rod and a little elbow grease the adapter and chuck came free!
No more dropping chuck screws while removing them while the chuck is on the lathe, no more trying to find them in all the chips on the floor.
The spanner is a ParkTools HCW-5 and the best $17 tool I've bought in a long time.
