older nova mini chuck *LINK*
darrin hill
I'm trying to identify and find out if parts are available for an older nova chuck...
i think its the precision mini chuck... friend has one and needs to replace one of the tightening lever thingy..
it's the top bar in the photo...
http://i37.photobucket.com/albums/e76/darrinthephotographer/darrin1234.jpg
Re: older nova mini chuck *LINK*
Nick Todd
It is an original nova chuck. The jaws are interchangeable with the supernova chucks.
D. Hansen
Darin that is the first (older) of the Nova chucks. I have a couple. Your Friend can simply use a piece of rod of the appropriate diameter in the hole where the regular "wrench" would go. I frequently use one of the rods with the nob on the end from one of the chucks and the similar one from the other in the two holes. All the "wrench does is to hold the body while the other rotates the gears moving the jaws. The "wrench" in my opinion should have been just a simple rod in the first place anyway.
I believe the rod diameter is 1/4" and....
JamieDonaldson
.. can be puchased at big box stores like Lowes. This allows the option to make them longer for better leverage as well.
Scott in Falcon
I have one of these original Nova chucks (along with a Nova G3 and a SuperNova). If you have a locking spindle on your headstock (for indexing) you don't even need the wrench. I lock the headstock, hold the piece I am mounting with one hand and simply operate the rod with the other hand.
If your spindle doesn't lock, then you do need a second rod.
Terry Scott
I agree just use 2 pins
If you want I have a leaver that I dont use
you can have if you pay postage
