I was given the lathe shown here: http://www.danmozell.com/lathe/lathe.jpg . It says Craftsman on it but doesn't have a model number of other info. Is this for wood or metal? Where can I find info on how to set it up, find a motor, etc. Thanks for your help.
It looks like a metal lathe, but I haven't any idea how old it might be or what its model number is. The tool rest is located in the wrong position. The tailstock should be in back of the tool rest area. My original woodturning in the late 1980's was done on a Sears metal lathe. I removed the tool post from the lathe and bolted a piece of angle iron onto the base. Then one could use chisels to turn the wood. You could probably use that lathe to turn wood with no problem. Good Luck.
Craftsman sold a wood lathe way back when that had a metal lathe style cross feed as an attachment. I don't know if that is what it is but it sure looks like it. Either way it would make a good wood lathe you just might need to rig up a tool rest of some kind.
This lathe may be a slightly newer version than the catalog or other changes have been made. Hard to see but I see no oil cups to the headstock bearings. Are these sealed or is there just a hole to oil the bearing with a fibre wick in them? The jack shaft is either a newer style or home made since it look like it has newer style bearings. Since this looks like a metal lathe the pulley system may be set up to run at a lot lower speeds than if you use it for woodturning. You need to look at what speeds it will produce with a 1750 rpm motor.
If the swing arm for the jackshaft is set up so the motor is mounted on the back underside then it may provide the belt tension and allow easily lifting the swing arm to move the belt for speed changes. Depending on how the motor mounts you may need a motor you can wire to run in reverse. Some old systems were set up for a double ended motorshaft to line up as mounted. If the motor is just table mounted then not sure how they easily changed belt position. Just comments, but you probably are up on them.
The Vintage Machinery catalog link is very useful. This stated the relevant motors were on page 42/43. Shows as 1750 rpm. Surprised the motor capacity was 1/4 - 1/3 HP. Feels low these days.
Places I would look for a motor in descending order
Grizzly Imports (where I purchased my most recent 1/2 HP motor)
Tractor Supply
Grainger (lots of motors, but high prices)
Harbor Freight
Garage sale.
Big difference in features between the sites and between models. For my recent purchase I wanted a TEFC (Totally Enclosed Fan Cooled) and better efficiency.
Also look for at least one capacitor to aid in starting. If two capacitors, one will be for starting and one for normal operation.
A big unknown is the motor mounting. I hope this is a normal NEMA mount.
Don't forget about searching for a new motor on eBay - there are LOTS of them listed, and you can get some outstanding bargains on top quality motors (Dayton, Baldor, etc.).
Also, you could check with a local motor rebuild/re-winding shop. Sometimes they have extra re-built motors for sale at decent prices. You might pay tax, but you won't pay shipping. They might be able to accommodate different mount types besides the common '56' style. I found a 3/4 HP motor for a band saw I was re-conditioning at our local motor shop, and it is excellent. They may also be able to set you up with the correct sheave and belt to match your lathe.
Good luck getting this one going; it looks like it is in great shape!!
