re turning a rough out dried bowl
Jerry Lear
I get bowl blanks from a fellow that roughs them out & kiln dries them, leaving about a 1" thick rim. When I begin to turn, the first thing I do is to use a jam chuck & true-up the tenon & do some rough turning on the outside of the bowl. I then put the tenon in my chuck & true up the edge of the bowl & begin turning the inside. As I am turning the inside, I have a difficult time getting the bowl true. The bowl seems to warp as I cut the wood away, making it difficult to get a good true inside surface. I then do some final cutting on the outside & sand & finish the bowl.
It is very difficult to turn w/the bowl warping as much as it does. I have asked other turners that the bowl is relieving stress as I turn, causing it to warp. I find it hard to believe as I have seen many turners turns the same type of bowl.
Are my procedures incorrect as far as the areas I am turning or is it the nature of turning a dried blank?
Any suggestions would certainly be appreciated.
Thanks,
Jerry
Back to top
Re: re turning a rough out dried bowl
Jerry there are a couple of possibilites. First of all of course is are they really dry. Don't know anything about your friends process but it's possible at least that they aren't really dry. Weight them and let them sit for a week or so and then weigh them again. If they change they either aren't dry or needed to aclimate to your shop.
Second. If kiln dried too fast they can build up stresses that are relieved when you take a way wood. Again don't know your friends process and he may know what he's doing, I'm just grasping at straws.
Last,if your tools aren't sharp and your forcing the cut the tool wants to bounce across the hard spots or end grain and cut more on the soft grain. That makes the bowl seem like it's warped but in actuality it's the tool doing the "warping" by cutting differently as it goes through the wood.
Where the wood comes from in the tree such as limb vs trunk can also have different kinds of stress in the wood that is releived when you cut .
Lyle Jamieson
Lyle Jamieson
I agree with John's list of possible reasons. Try solving the problem by turning in stages. Only turn the first inch or so of the rim of the bowl first. Get the first stage completey done inside and out before moving to the second stage. This will leave support behind so the wood will not vibrate, flex, or get out of round. This is not easy. It is hard to get a nice curve for the bowl when you can not do the whole thing at in one line.
Barbara Gill
I too would first suspect the drying process. Incomplete drying would lead to warping as would too fast drying.
I once tried drying bowls in a kiln but even with slow careful drying I didn't think the results were as good as air drying.
