SketchUp as a DESIGN Tool for Multi Axes Pieces *LINK*
charlie belden
A couple of months ago, Peter Rand e-mailed me several photos of a two axes turning he'd done that appeared to have a 180 degree twist in it. Having stumbled upon something interesting, and having trouble repeating it he was asking several people to help figure out the HOW. Knowing Barbara Dill's interest in multi axes turning, I sent the problem along to her. Over the next several weeks a collaboration solved the mystery. Turns out you CAN'T turning a piece with a 180 degree twist - but you CAN get pretty close - say up to around 170 degrees.
Having used SketchUp to create virtual 3D models of two axes, 90 degree twisted pieces, thanks to Barbara Dill's articles on multi axes turning, I went at Peter's problem using SketchUp. And in the process, I went searching for a way to use SketchUp as a DESIGN TOOL for working out multi axes ideas - VIRTUALLY - and found one that's promising.
Then I wondered if the method I'd come up with could be used to "reverse engineer" and interesting multi axes piece I'd seen over on WOW. Found one of Peter Rand's pieces, Femme Noire, that had photos of several views of the piece, one being a profile shot. From that side shot I made a SketchUp profile of the "front" and "back" of that profile, "spun" each and overlapped the result, then "intersected" the two shapes, creating a "common volume" space where they intersected. Deleted everything but that "common volume" (a Bolean A AND B type thing) and got a decent virtual 3D approximation of the actual piece.
A little tweeking of my origiinal two profiles and I did several variations of Peter's piece ( Femme Noire).
Here's the YouTube vid (hopefully embedded in this post) of the process
Web Page on HOW TO
