My first try at using In-Lace
Dave Paine
This is my latest board made as a thank-you gift for a colleague. She had seen some of my other boards and expressed a desire for "something with Bubinga" since she fell in love with its grain pattern.
I did not want to cut the piece in half so that I could maintain the grain pattern she liked. So I went with an asymmetrical design.
After gluing and sanding flat the yellow heart strips ended up not being as tall as the other pieces. The board was about 1 1/8in overall height, so enough that I could have sanded off the 1/16in difference, but I hate to cut away good wood.
I had seen the user in In-Lace at a recent craft show in March and then had looked at examples on various web sites. Most of the examples were in turning, but I decided to give this a try for this flatwork and so routed a 3/8in groove and filled with turquoise In-Lace. Easy to apply, just not efficient. A good amount gets wasted each time. Have to measure the hardener carefully. Hardens in 12 - 24 hours. Easy to sand but you need good dust collection.
This was the result. The recipient liked this. I like the way it makes the board look to be less asymmetrical.
I was making a separate board as thank you gift for a different colleague, and felt I should use In-Lace this in this one as well. For this board, I just routed 1/4in groove in the side edges. I think I like this application better.
Both boards were well received. I think In-Lace can be a nice embellishment in some projects flat or turning. I did get some calibrated small plastic cups.
The instructions state 10-15 drops of hardener per ounce of resin and do not add too much hardener or else it will not harden. :\ Hence the need to measure carefully.
Re: My first try at using In-Lace
In the first example
Gary Smyth
is the In-Lace stopped at both ends or is it an illusion? If so, does the In-Lace have to be stopped? The second example carries the color end to end. Nice stuff. I challenge you to give me a YEAR when the recipient's knife edge will first touch the face of the first board.
pecker
I used the same product and was very happy with the results.
I just wish I had some use for all the leftover Inlace. Even the smallest size goes a long way.
Re: In the first example
Dave Paine
Gary,
In both boards, I applied a piece of masking tape at the ends to prevent the In-Lace from "falling out" before it started to set. It does not take much to stop it, but it needs something.
The first board was routed at the end edge, so the yellow heart is showing a little.
Both recipients will be using these as decorative boards. In case you are interested, this is what the second board looked like.
Top view. After assembling this looked like it needed "something" so I inlayed the rosewood bow ties.
This is the bottom. I had a "drop" from some curly maple pieces. I attempted to pop the grain with amber dye in shellac. The right side looks better, I think the flash drowned out the grain.
