Tasmanian Eucalyptus box
Dick Hines
Dick Hines
Latest box. It's 5 1/4d x 7h. Lots of hours doing the handle. These handles are getting more inviolved. It seems the one I am working on took more time than the last.
Re: Tasmanian Eucalyptus box
Keith Tompkins
Keith Tompkins
Hi Dick, I like the effect of the turquoise...it appears tree roots are emerging from the vessel. Great effect.
Mike Stafford
Mike Stafford
Dick, another beauty. You continue to expand the number of limbs on the tree and by doing so you are increasing the character of the tree.
I like the way the turquoise peeks through the cracks and like Keith said it makes you think of roots poking through the soil.
Beautiful!
LOST WAX CASTING . . .
charlie belden
would make all this SO much easier and even allow surfaces to be textured like bark. And, like the soldering/welding you're currently doing, is an additive process, but lets you make changes SO much easier and quicker to do. Don't like something you added? No problem. Remove it with a hot tool - like a needle or Xacto knife. Want to taper a branch? No problem. Roll some softer wax out to the taper you're after and then, with a small hot tool, heat where you want to bend things and bend it. Want a sharp bend - heat and bend to the angle you want. Want it to look like a branch broke off and the tree healed around it? Add a little blob of wax where you want that effect, let it cool and spin the tip of a sharp Xacto knife in the center to create a small indentation where the tree didn't completely cover over the damage.
A small alcohol lamp, some dental tools your dentist probably would give you, $15 work of an assortment of wax wires (them come in a range of gauges) - or Roll Your Own and you've got what you need for the wax working part of the process. Unfluxed bronze brazing wire makes excellent casting material and it's relatively inexpensive and available.
The casting equiptment is moderately expensive but if you're in or near a major city you can probably find a hobbyist doing casting who would be willing to do some casting for a nominal amount - especially if you offered one of your finished pieces as a deal sweatener.
Alas, I gave all my casting equiptment to a jeweler friend, or I'd offer to do the casting for you.
ANOTHER possibility is Electro Forming. Make your shape in wax, spray it with a conductive paint and heavy plate copper on to the conductive surfaces When you've got the thickness of copper you want, you can melt out the wax in the oven, or leave it in.
Here's a DIY set up that'll let you try electroforming. Of course, when playing with car batteries - take necessary precautions to avoid shock. And even a dilute acid can harm you.
