I feel like someone holding a screwdriver and asking how to use it.
How do you power sand the inside of a bowl? With the lathe in the forward direction where do you sand, 12, 3, 6 or 9 o'clock? I'm guessing it is just the opposite when in reverse. Do you start at the edge and move in toward the center or from the center out?
What about pad size in relation to bowl size and what part of the pad is used? Is it used flat so the entire pad is in contact or should it be tilted so only say a third is in contact? Should the drill direction be changed from forward to reversed?
I use a vsr drill with mandrels and discs from steve worcester 'cause in my humble uneducated opinion they are the best. My lathe has no reverse but it doesn't matter with a reversing drill. I start at the rim and work to the center and don't skip any grits. Thanks, Russ Fairfield, where ever you are!
That is way more than a question or two. I could write a book....
I prefer the angle drills as opposed to the right angle drills. Just easier to get the disc inside the bowl and all the way across the bottom.
When sanding the outside, I tend to use more of the center of the pad, and when sanding the inside, I tend to use more of the edge of the disc. If you try to keep the disc flat on the wood like the flat part of a plate, it gets kind of grabby because so much abrasive is in contact with the wood at one time, kind of like trying to take too big of a bite with your turning tools.
No need for reversing when using the drills. I am in the school of slow speed sanding. My drills have ranges up to about 1300 rpm, but I keep the speed to half or less. The abrasives just seem to cut better.
For rotation, I prefer to keep the edge of the pad that is in contact with the wood spinning away from or off the rim, rather than spinning into the rim. Main reason is some times it will dig in. I keep the drill going counter clockwise, so inside the bowl, I have the disc/sander, most of the time at 9 o'clock, and working with the upper edge in contact with the wood. With the outside, most of the time, I have the drill between 9 and 7:30, and working with the lower side of the disc. You can start at the rim and go down or from the center and work your way up. I think on the outside, I start at the bottom most of the time, and change that up a lot when turning the inside.
Another point is interface pads. You have a mandril which goes into the drill, and you mount your discs on it. They are fairly expensive. You can get all sorts of pads to go on it so they wear out first, and they are much cheaper than the main mandril. I keep the firm pads on for the coarse grits, up to 220 or so, then switch to a soft of medium. 120 grit on a firm pad cuts better than 80 grit on a soft pad. For the firm pads, I like the ones from Vince's WoodNWonders. They have a 1/4 round profile on the edge which do a much better job on the inside of the bowl than a square edged pad. I also prefer his abrasives. He does have a lot of info on his web site about sanding.
Another note, do not 'press' when you sand. Just the weight of the drill is more than enough pressure for sanding.
Get one of the eraser/crepe sticks for cleaning your discs. The abrasives are cutting tools, and they don't have a long life, and can not be sharpened. Learn when to toss them rather than trying to get just a little bit more out of them.
Mike Mahoney has a good u-tube video on power sanding. I think his methods make good sence and have worked for me so far. I also have just started to power sand so I bought an angle drill which works pretty good.
I always sand the inside starting at the 9 o'clock position and proceed from the rim to the bottom and back to the rim.
I most often start at 120 grit and reverse the lathe rotation on every grit change. I use 120, 180, 220, 320, and 400 and finish up with the white scotch brite pads. This seems to work well for me.
I do not use a right angle sander, as I feel it is not needed for the bowls I turn. I have an old Dewalt DW 106 that works great. I run the drill motor full speed(2500) and the lathe at about 500 rpm.
Sanding takes about 30 to 60 seconds on each grit for me.
Personally, I sand mainly in the direction of the cut, (counter clockwise) with the sander running in the same direction, at 9-7 o'clock. If you run the sander in the opposite direction to the bowls rotation, it works but is far more aggressive. Perhaps a good approach in the 80 and 120 grits. Other than that, I agree with Mike. Not that anyone else's approach is wrong, I just use what works for me.
As for interface pads, I stick with the mandrel unless it is an out of round bowl and then use a thick soft pad to counteract the undulation of the warped bowl.
Most people sand with the lathe going in the forward direction and sanding between 7-9 o clock. 2" pads are used for smaller projects such as 10 maybe 11" and 3" pads generally tend to be use up to 14- 15 inches. Beyond that a 5" set up works well. Feel free to call me with questions and/or samples.
