Re: PM3520 Spindle Lock Improvement
Craig Daymon
Why make it so complex?
I marked the mid location of the button on the edges of the surrounding guard. Then I took the guard off, fitted it with a piece of wood to support the edges of the guard and drilled a hole through the side and passing through the other side.
Then I cut a piece of round steel bar stock, about the same diameter as the piece used in the photo. 3/8", and about 5/8" longer than the guard is wide. Grind down the ends so there are no sharp edges.
Put the piece in a small v-block and drill a 1/8" hole through the rod about 1/4" from an end. Run a piece of wire, maybe 3"-4", through the hole and tie it off. Put the guard back on the lathe and, before putting in the bottom screw twist the other end of the wire around the screw.
When you need to lock the spindle, Push the button in and slide in the pin. When you don't, just let it hang there.
That's what I did. Easier than cutting slots in the guard and bending the rod.
-Craig
