My wife turns only small stuff. Usually less then 2" diameter. She had me make some rubber grippers to screw onto the holes that hold the jaws onto a small chuck. Using the center holes, she can grip already finished objects (less than 3/4" dia) that have already been finished. No scratches. This works good so that she doesn't have to use a Dremel, etc to clean off those little nubbins. Rubber corks from Lowes and some 4mm x 18/25mm flat head screws. I shortened the stoppers, drilled, and countersuck the heads on the lathe with a dreaded skew. Total less than $10. This will work with ANY lathe and any chuck. Adjust dimensions to fit our stuff.
I did a WC search before posting, and got through the first page or so of hits. I was not seeing anything related to making them and got impatient and posted my question. I have read this well done article before, but forgotten! In fact, that's likely where I got the idea that I could make them.
Ditto on the Longworth chuck; have the Cole jaws and haven't used them in the year I have had the Longworth chuck. In fact, I had thought of putting them up on the benefit auction. This thread just gave me the impetus to do it. Look for posting and pix this weekend.
I did something similar (due to a suggestion from Dale Larson). I added 8/4 maple blocks to a Cole jaw set, and then cut a rim in at at (each) required diameter. I find the attachment more secure then the 8 points of the Cole Jaw
Which brings up another point, there are 4 point, 6 point and even 8 point "Longworth" designs out there, IMO the more points the better. I would not build (nor recommend) the 4 point.
I made a set years ago out of baltic birch plywood and they worked well. Eventually I bought a "real" set from Wood Craft. They will hold a bowl about ten inches in diameter. Then I made extensions for them so i can grip bowls up to 16". I really like the extension. Not sure I Still have the wooden ones but if I do, I would give them to you. They were fine, but I have moved on. They fit on the Nova chuck that uses the Tommy bars.
I made multiple plywood jaws of any sizes I needed. I finally bought both large and small coles for my Axminster. I also had extensions made so that I could reverse to the max of my lathe.
Re: Thanks all; looks like a Longworth style it is
Grant Wilkinson
Henry: I've made 3 different Longworth chucks. Until I got to the last one, with 8 buttons, I wasn't happy with them. With 8, it holds very well. As Ralph advised, I would stay away from the 4 button plans.
