So, I want to try bowl turning. Been reading Conover and Raffan books. Eager to get started. Only have spindle tools right now, so I want to buy a bowl gouge. Recommendations on size? I need a compromise size to start with: What's going to be the most practical size for all duty?
Chucks: Is it worth investing in a chuck now, or should I go with glue blocks and jam chucks for now. Is there a distinct increase in ease with a commercial chuck?
I'm still reading, so sorry if these are noob questions...
...we need to know what size lathe and bowls you intend to turn. My go to gouge is the 5/8" deep flute, but for smaller work the 1/2" is better suited. Be aware that these are US measurements of the tool steel diameter, not the flute width as measured in European made tools.
What Jamie said (and asked) is correct (of course!)
If you have a mini-lathe, get a 1/2" BG (bar size). Doug Thompson makes a nice one that I use all the time.
If you have a 12" or larger lathe get an Ellsworth Signature BG (5/8" steel) and one of his sharpening jigs. It is a "universal" tool that you can't go wrong with.
For basic bowl turning, I would recommend 3 basic tools. One round nose scraper, and 2 gouges. You need one gouge with about a 40 degree bevel for cutting the outside, and the inside walls, and a gouge with about a 60 degree bevel for going from the wall through the transition, and across the bottom. The scraper can also clean up the bottom, but you get a better finish cut with the gouge, at least when you learn how to use it properly. The scraper is good for general clean up work when the gouge is not cutting smooth, and the surface looks more like a washboard. This cut is made at a shear angle rather than flat on the tool rest.
Chucks are a great convenience, a bit on the expensive side, but faster to use than jamb chucks and waste blocks.
I use my 1/2" bowl gouge for almost everything from 20 bowls down to tiny stuff. For beginner I would recommend a 1/2" bowl gouge, and a thick round nose scraper.
You could use just a Hunter Hercules tool to turn bowls. It will do both the inside and outside as well as some more advanced techniques. You can also use the flat and round EZ woodtools. The advantages of these tools is that you don't need to sharpen them. I still prefer a bowl gouge because I think it's a more all around usefull tool and you said you have other tools which tells me you probably have a way to sharpen.
You don't need a chuck. It does speed things up and I know a lot of turners are impatient but I turned for a lot of years using faceplates, waste blocks, glue blocks and jam chucks to turn all sorts of things. I was probably 10 years into turning before I owned my first chuck.
Jamie, my Delta 46-700 (I think that's the model) swings 12", so that's my max, but honestly, I'm looking smaller than that for now. So I'm guessing 5/8"?
...about 5 lathes ago, the 1/2" will do just fine. I believe any bowl turner would benefit by owning both a 1/2" and 5/8" as a working pair, and those are 2 of my basic set of the first 5 tools that every bowl turner should buy.
I'm a borderline tool junkie/GAS attack fool to begin with, which is why I lean toward getting a chuck now while I have the dosh. All my tools are Packard, and so far I've been happy.
