Took me a minute...
Took me a minute...
Steven Antonucci
Took me a minute...
steven antonucci
to figure this out. Enjoy:
There will always be someone with less than you...
Steve
Re: Took me a minute...
Curt Stivison
I guess you don't have to worry about what speed to set your lathe on.
what speed to you turn at-3450
that's pretty cool. Hope he doesn't make anything large.
I don't recognize what he used to......
JamieDonaldson
..make the tailstock quill?
Almost looks like an arbor to make a buffer.
Steven Antonucci
make sure not to use the handwheel
steven antonucci
What I can't fathom is that he turns for 4 minutes at 3450 and only removes that tiny little bit of wood. I bet he wears a faceshield (and earplugs!)
Steve
Re: make sure not to use the handwheel
Lynn Taylor
I think he is turning on the wrong side of the lathe and, therefore, the piece is turning backwards!
Nope-that end of the grinder would turn correctly
Steven Antonucci
It is not a lathe
steven antonucci
look closely, and you will see that his headstock is a grinder that he's rigged up to spin the wood, and frighteningly fast for his level of ability I might add...
The grinder is rotating towards him, so in this case, he's on the right side... although I would suggest that there is no right side in this set-up.
Steve
I need to rig up a photo of my first lathe
I was building a cabinet and wanted to turn some knobs. I mounted my drill on my workbench with a band clamp to hold the on switch. I made a wooden tool rest that was clamped to the workbench. Put the blank on a screw that was stuck in the jacobs chuck and grabbed my sharpest screwdriver and made a couple of knobs.
Dick Hines
Re: I need to rig up a photo of my first lathe
Dick Hines
Holly ****!! When the video started I ran to the shop for my face shield.
Speed roughing won't happen when.....
JamieDonaldson
...he's using a skew as a negative rake scraper!
Mike Stafford
I have for so long....
Mike Stafford
done so much with so little I can now do almost anything with nothing......
Rob Wallace
Re: I have for so long....
Rob Wallace
"Never was so much owed by so many to so few..."
British Prime Minister Winston Churchill
20 August 1940.
R Payne
Is he turning at 3450 or 1725?
That isn't that different from what I learned on. Only I didn't have the hand wheel. I inherited what is best described as a motor with a drive spur and a dead center on the far end. The motor was old enough to have oil ports and was single speed at 1725 rpm. I stopped using it when the wiring started sparking when I turned it on.
ron
Looked like a bench chisel to me!
Terry Scott
Ive been telling you that a skew is the best scraper I have (grin)
Was that a washing machine in the background
Painful to watch when with a skew cut that could have been cut in seconds
