Turning beads video *LINK*
http://www.youtube.com/watch?v=bjYehUsMdB4
Re: Turning beads video *LINK*
#2Re: Turning beads video
Lloyd in Mississauga
Great video John.
What about adding in Al Stirt's method of turning a bead? I had watched it a couple of times and can not quite get the break down of the tool movements as he seems to start on one side, and cut up the side, over the top and then down the other side of the bead.
Lloyd
#3Re: Turning beads video
Do you mean Richard Raffen. Sounds like the same method. I tried it. I haven't played with it enough to be good at it. My beads are different sizes and shapes when I do that. I know it's faster and maybe I would get it down with practice but for now I prefer the uniformity of the ones I do now.
When I do long sets of beads like on my Mayan mirror or the entire outside of a bowl I do all of the right sides in one pass and then all of the left. It goes very fast this way and muscle memory after doing the first few really speeds things up.
I don't do the V cuts most of the time now because I can really twist the side of the spindle gouge into to the cut. I don't usually teach that method because it takes lots of practice.
Mike Stafford
I agree it does sound like the method that Richard Raffan uses.
It takes a little practice and a sharp tool but once you get the hang of it you can turn a lot of beads in a hurry.
#5Re: Turning beads video
DaveL
John:
Would you consider doing a video on captured rings? I have been turning for a while now and it gives me fits turning a clean ring. thanks.
#6I'll try to get one done some day soon
#7Re: Turning beads video
Galen Vetterick
Thanks John for another fine video demonstration. Also shows you do not need expensive tools to cut beads, just experience!
It had me fooled for a minute as the alternating wood color, lathe speed and frame rate I was viewing made the spindle look like it was turning in reverse.
#8Re: Turning beads video
Yea that didn't show up on the camera but when I saw it as I downloaded I was glad I didn't slow the lathe down a hair or it would have looked like it was standing still.
#9Another excellent job John!
