wood turners finsh
wood turners finsh
Dan Jechura
wood turners finsh
dan Jechura
Has anyone used General Finishes " Wood turners Finish" ?
An if you did. Did you like it?
I tried it tonight and I am unsure if I like it yet.
Dan J.
Re: wood turners finsh
I have switched from GF High Performance.....
JamieDonaldson
..to their WTF because it dries much faster, and can be applied just to seal, or build multiple coats to a surface as desired. It remains clear on light woods that I frequently turn, and I like it.
Alan Zenreich
Re: I have switched from GF High Performance.....
Alan Zenreich
I have used it a bit and rather like it.
The instructions are a bit ambiguous for airbrush application.
Are any of you thinning the mix, and if you are, is it only for the last coat?
Dale Bright
I am in agreement with Jamie, I really like working with WTF. It can be airbrushed right out of the can and clean up is just soap and water.
Dale
Jamie, I'm curious...
GaryG in MD
I've been reading about this stuff with interest but don't understand something.
You used the expression "clear on light woods", but the product literature contains the word "amber". I can't resolve those two together.
Oil finishes, which I like, amber wood, which I don't necessarily like.
I'm trying to stay away from ambering in lighter woods by going to water-based acrylics, which, unfortunately, don't 'pop' the grain as well.
What's the story on GFWTF? It's an oil/water blend. Does it amber or not?
Thanks, Gary
carl civitella
I have used it on a couple of pens, it is very user friendly. It ambers some but not as much as oil. It is a pleasure not to handle c/a. I am using the pen daily for awhile to see how it holds up over time. Carl
Re: Jamie, I'm curious...
Dale Bright
Gary,
I have found that GFWTF does amber the wood some but not nearly as much as straight oil finishes nor as mush as Danish Oil or Antique Oil.
Dale
thanks Dale...
GaryG in MD
That's good to know. ...Gary
Dan Jechura Temperance Mich.
I was useing it on Oak last night and it raised the grain, is that common? Because it's water based?
Dan J.
I hand apply my finishes, and seldom .....
JamieDonaldson
..apply more than 2 coats unless I'm building gloss lacquer on my dyed pieces, to enhance the chatoyancy! I've been using a thinned coat of lacquer as a sanding sealer for years, and may start using the WTF for that duty as well, although it does raise the grain a bit. With so few coats I haven't had any objectionable amber on my light colored woods.
Scott Hurley in N VA
A couple of folks have tried it on pens. It's easy to apply, but their comment is that it doesn't dry very hard for several weeks. During that time, it can be easily marked with just a fingernail. I have a bottle, but haven't tried it yet.
Scott
Bernie Weishapl
I have been using it for 3 or 4 months now and love it. On pens I can put on 8 to 12 coats with the assist of a hairdryer on low in about 35 minutes. I haven't used CA since. Yes it will raise the grain but after lightly sanding the first coat no problems. I use it on most anything not utility. After drying for 24 hrs is pretty hard and have never had a pen come back or have had a pen get scratched.
Ron Solfest
I'm with Dan, I haven't made up my mind yet. On the plus side it's water based for clean-up, dries very quickly, and builds to nice hard gloss quickly. On the negative side it's water based so it raises grain somewhat, it's also not 'clear' but also not the blue of many water bases. They seem to have added a pink tink to knock down the blue and try and impart a slight amber. On the oak bowl I used it on it looks starker than I expected, certainly not the amber of oils.
I'm going to keep trying it but my mind still isn't sure...
