Oval Spindles
Oval Spindles
Oval Spindles
Bob Lalonde
My daughter-in-law, Erin makes exquisite, artistic jewelry. Before I knew what I was getting into, I agreed to make some oval mandrels that she would use to size bracelets. After looking more carefully, I realized that I had no clue how to make an oval spindle. The link below will clarify.
Can anyone help me out with this. You may wish to make them as well if you can get 30 bucks a pop.
Thanks. Bob.
http://www.riogrande.com/Product/Solid-Wood-Oval-Bracelet-Mandrel/112172?pos=4
Re: Oval Spindles
Re: Oval Spindles
Peter Hyde
Bob, do a search on oval hammer handles and you will find the answer.
Multi center and pretty easy.
Re: Oval Spindles
Re: Oval Spindles
Michael Mocho
Hi Bob,
If you don’t have an oval attachment for your lathe ($$$$$), you may be better off just buying the mandrel. The best you can do on a conventional lathe is a lenticular cross section- turned by shifting the axis proportionally on both ends of the cylindrical spindle, which still leaves a ‘hard-line’ transition where the two turned surface merge. A 6 x 48 belt sander may get you closer faster, but you will still have to keep it symmetrical by eye. There are other ways to produce them, but in the long run, I think it will be faster and cheaper just buy the mandrel.
Re: Oval Spindles
Hand tools
Specifically a draw knife and a spokeshave. I've made many an "oval" tool hand with a draw knife and spokeshave. It really doesn't take that long.
Re: Oval Spindles
Re: Oval Spindles
Peter Hyde
I guess you have never done it and haven't used sandpaper to soften a shape either. A quick easy thing to do and something to add to turning skills
Re: Oval Spindles
Re: Oval Spindles/another method
mjonesrdg
I think that I could do this on the lathe faster than choose good phrases to describe it, but I'll give it a shot. Charlie Belden could draw this for you in a snap also.
The basic concept: Glue together 3 boards of equal thickness using paper between the glue joints for easy subsequent separation. From the square, turn a cylinder. Split the parts and remove the center board, then make a good and permanent glue joint and join the two outside pieces together. It's an oval. Might be way not the size you want, but now you know the basics.
Now to refine the process: Draw the oval shape and size that you really want, and notice that some elliptical forms are "fatter" than others. Divide the template into three parts with the center piece being the best thickness to produce the proportions that will best fit your bracelets. This may not be a thickness equal to the other two.
My mind's eye tells me that your cylinder could taper and still work just fine with this method, but if not, make three of four of them at different sizes.
Refine the piece You can turn the piece between centers if it comes out too 'football' shaped (in cross section)...or just blend the arcs with rasp, sander, or other.
Hope this is understandable...and that it helps.
Mike Jones, in Redding, Ca. (88 deg today!)
Re: Oval Spindles
Bruce Pratt
Mike,
The lost wood process you describe still gives a lenticular cross section, not an ellipse. It is functionally equivalent to the off-center turning option that Michael previously mentioned. However, this method, plus a bit of sanding will get one pretty close to the desired endpoint.
Re: Oval Spindles
Re: Oval Spindles
Peter Hyde
Bob this may clarify
Black X produces black circle
Red X produces red arcs to give an oval
Blue X produces blue arcs to give the lenticular effect
Green X corrects that effect producing an oval
So as you can see the further away from the original center the worse the lenticular effect becomes but it can easily be corrected by using another center on an axis at 90º to the original and the same distance away from the original circle's center
Re: Oval Spindles
Peter, I think you may want to rethink
Keith Newton
The last part with the green x's. Seems to me, you would be right back to a small round, when you finish drawing the missing part of each circle.
Re: Oval Spindles
Re: Peter, I think you may want to rethink
Peter Hyde
No the green arcs are rounding off the points on the blue arcs and are at different radii. Could also be done freehand with a block of wood and some sandpaper.
Re: Oval Spindles
Error in the drawing ... ?
Doc Green
It appears that the top green X was used as the center to draw the top green arc. I believe the bottom green x should be used to draw the top green arc. And vice versa.
When actually making the cut, you will simply knock off the sharp points without making the cut too deep, so the "problem" is simply with the artwork.
Clever method!
Re: Oval Spindles
Re: Error in the drawing ... ?
Peter Hyde
Thanks Doc.
I was fudging it a bit :) Anyway here's the corrected drawing and as you can see there is some minor sanding needed to complete the oval. In practice it's easy to move back to the true original centers and sand with the lathe running
