(Message Deleted by Poster)
Re: 3520 won't restart after stopping in thunder
Greg Burnard
Aage, I've solved that problem by unpluging the motor. have a cup of coffee, plug it back in, and it runs. Why Don't know, Greg
Works again: can anyone explain what happens?
Aage Rendalen
I accidentally deleted the posting. I've used the turn off the power and wait method before, but this time it didn't work, until it suddenly decided it would. Does anybody know why these shut-downs happen and why it can be troublesome to reset it?
Re: Works again: can anyone explain what happens?
Peter Hyde
If you unplug or disconnect with a switch on the power outlet you will force a reset in the VFD. I always disconnect after every session on the lathe and never had a problem. Power outage after a storm always needs a reset so the only way is a disconnect and it should reset. It sometimes takes a couple of tries.
Scott Crumpton
The VFD is nothing more than a small computer connected to some high power control circuits. Just like your desktop computer it needs a stable source of clean power. If a power spike or dip gets past the minimal input filtering present it's quite likely to make its way into the processor and disrupt it at best. At worst it could fry it. Sometimes the effects can take several power up/down cycles to fully clear.
I think Powermatic did us all a disservice by not putting a hard power disconnect switch on the lathe. One should always unplug the lathe when not in use or connect it to a circuit with a 2-pole power disconnect and turn it off after use.
John Veerkamp
I have mine on a double pole switch and always turn it off after use.
