Sanding needles *LINK*
I was in Hobby Lobby this week searching for Iwata airbrushes and found these sanding needles. They also have other small sanding pads and files that should be very useful. The sanding needles work very well. I tried them out tonight and was very impressed. There a little expensive. I'll have to see how long they last. However they will reach into places that are very hard to reach with my other sanding tools so I think they may be worth it.
http://www.alphaabrasives.com/alpha/plastic-sanding-needles.php
Re: Sanding needles *LINK*
Re: Sanding needles
galen vetterick
I imagine they are too big to sand your minature goblets. :D
Only coated plastic *LINK*
Jennifer Indy.USA
I've tried these. I wasn't impressed. They are just thinly coated plastic sticks. The grit rubs off in no time. When I bought them I was hoping they were impregnated but found out differently. Rio Grand has some nice sanding mandrels used for jewlry making that are slotted so you can use whatever grit you want and they'll last forever. They are in all diameters and conical too. Made in Germany and are cheeper than these plastic things. I've included a link to Rio Grande.
Jen
ASSORTED MANDRELS
Re: Only coated plastic
I have one of those but it won't reach into the really fine places and if you need to sand into delicate surfaces like piercing it can break them. They are great tools and I recommend them. However they are rotary tools and sometimes you need something more like a file.
thanks for the comments on the sanding needles. I will use them more in the near future and will have a better since of how they hold up. Like you I thought they might be impregnated. Maybe we should develop some and go into the market?
Jennifer Indy.USA
John get some bamboo kabob skewers at the grocery and use some 3-M spray adhesive to attach a thin strip of your desired grit to it. Just lay them flat and roll the strip on. They're sort of flexable, can be cut to length and you get about 20 of them for about $2. Great for stuff like this!
Jen :)
Don Evans
I have not tried these but instead use miniature files which I like. They last a long time.
One that I have is an aluminium handle with collet. Handle is about 3/8" diameter and the files fit in the storage area in the top. Also have a set of (actually several sets) of rifflers, files and rifflers from miniature to larger sizes.
www.ptreeusa.com also sells sanding sticks that has abrasive on two sides and flat files double sided and both have foam in middle, use lot of them also.
On the mandles for rotary that Jen pointed out, you can also get them at any carving specialty and although they are made for rotary I used them lots of times by hand.
Good tip on the skewers also Jen.
Don
Jen I'm a fan of 3M spray adhesives and make my own sanding sticks of what ever shape I need. The small round ones are the hardest to make. Flat is no problem. Of course your probably aware of fingernail files. You can cut them with an razor knife to get thinner shapes.
For my next mirror I'm working on I will need some thin very stiff abrasives so I'm thinking about bonding sandpaper to steel banding pieces. I think they might be thin enough to reach into the spaces I need.
Cool That place is really near my parents house where I'll be staying next weekend. I may have to leave early for the Southern States Symposium and stop buy there. Of course I'll be working a 16 hour day the day before so getting up early may not be the easiest thing to do. Still good to know it's there. I can stop buy next time I go home.
Don Evans
Did you notice that they are also associated with 2 or 3 other stores? You order something on the web site and it may come from any of the associated stores. I've used them for several years and get stuff 2 or 3 days later.
One of the stores is bandsaw blades looks like 5 stores at one site on web. When you first log in look on left side and scroll to bottom and you'll see the links but you don't have to go to them individually just depends on what catagory you pick (pictures) to the right of there to who you are ordering from.
Don't know if all these places are one warehouse or what but one of them listed is for only Freud stuff.
Also another site you may like John is www.micromark.com
Don
Love Micro Mark- spent lots there
Alan Zenreich
Re: Love Micro Mark- spent lots there
Alan Zenreich
I have several micromark machines, including a small metal lathe and a mill.
I used to drive down to their retail store and check out their specials... great fun. Unfortunately they stopped the retail operation a few years ago.
