Problems with Vicmarc VL300
gtwilkins
I haven’t used the lathe for a couple of months but it was working perfectly the last time I shut it off and unplugged it. The lathe has a Fuji FVR-E11 220 Single phase VFD.
Now when I plug it in I have no sign of life, the LCD display remains dark.
So far I have checked:
Voltage to the lathe and to the main switch on the inverter panel is good.
Removed main switch and tested with ohm meter, appears good.
However when I test the voltage across the switch with the switch off, with the lathe plugged in I have voltage on both terminals of the switch.
Has anyone experienced anything similar or any ideas how to further troubleshoot this problem.
I can’t find a reset unless it is inside the VFD
Thanks Trevor
