5/8" two spur drive center....
Phil Stivers
Phil Stivers
I am looking for a 5/8" two spur drive center. They don't appear in the catalogs. Any ideas? Thanks.
Re: 5/8" two spur drive center....
Mike Stafford
Re: 5/8" two spur drive center.... *LINK*
Mike Stafford
Phil, Packard Woodworks offers a 5/8" 2 spur center in #1 Morse taper but I don't find one in a #2 Taper.
See link:
2 Prong Centers
Phil Stivers
Phil Stivers
Thanks Mike. I sent them an inquiry on a 2MT version. Hope one is available...
Lyle Jamieson
Lyle Jamieson
Phil, I prefer not to use two prong drives. They damage the wood way down deep like a splitting wedge. It is worth the time to take a bench chisle and make a flat spot for a 4 prong spur, if the wood has a bias or uneven surface.
Bruce Pratt
I made one out of some 1 1/4 strip steel. Ground two chisel edges with opposite bevels and a point spur in the middle. Clamp it between the #2 jaws on a Oneway chuck. Not elegant, but seems to work.
Bruce Pratt
Phil Stivers
Phil Stivers
Granted the wedge effect of the two prong drive but in this case it overshadows the flexibility in placement and adjustment of the rough stock while shaping. I can adjust the rotation to present or avoid bark or other defects/features at will. Doing so with a 4 prong drive seems to clog the drive and cause it to slip. Pressure is maintained on the tail center to keep the drive in contact. This 5/8" drive is for small forms with an opening not much larger than that.
Phil Stivers
Phil Stivers
Hmmmm, that's an idea......
