I'll be doing a platter demo in may for the Down East Turners club.
It lasts 2 hours and I really do not take that long to turn a platter. usually around an hour unless there is a problem grain. I will not sand in there.
I start from visualizing the finished piece, perhaps making a template, choosing the wood, mounting it and turning it and discuss several ways of finishing.
Need ideas of how to pad my presentation to make it last 2 hours.
You may want to discuss and show by finished example different surface textures, profiles, or finishes. Also alternative mounting/chucking methods. A discussion of pros and cons for different cuts needed for different grain orientation or difficult woods. This can fill a bit of time if you need it.
You might want to talk about methods that you used to use, and why you replaced them with what you do now. You might also bring in older work to illustrate some of the types of problems you have to solve that you cannot show in a demo.
Talk about of even show different rim possibilities, from wide rim to narrow, how the tilt of the rim can change the look. Do you use a shadow line or bead to seperate the rim from the bowl. Texturing the rim. You could do offset feet on the bottom of even carved feet. You could turn a seperate foot.
If it could be a wall mounted piece, how do you mount it, what type of hangers to use. There are a huge variety from flush mount to wire. I have even designed an earthquake proof wall hanger.
.....a few of your favorite recipes for the food you like to use on your platters!
Good suggestions above..... ....also, the kinds of finishes that can be used, more desirable and less desirable wood species to choose for platters, and design elements such as the proportion of the rim to the dished-out area, the angle of presentation of the rim to the table surface, and the diameter of the foot compared to the overall diameter of the piece, etc.
You might demonstrate the effect of different tooling techniques and why you prefer one over the other. You know why this grind works better in this application than another grind.
You could also demonstrate various rim embellishments.
Show alternative methods of holding the wood (expansion, compression, glue block etc.)
Show various rim treatments i.e. rolled over rims, rims that are functional handles, undercut rims etc.
Show how to make the bottom as interesting as the top.
Discuss or demonstrate reverse turning.
But in the end I always fall back on my song and dance act.....
I think the biggest problem a lot of people have in turning a platter is getting a good smooth flat or slightly dished bottom straight from the tool. Point out how to 'feel' with your fingers what the bottom is like. I also check with a small straight edge. I demo how to remove a cone in the center. How to remove ripples. How to take the outside down (too much dish) to meet the center. Scrapers vs gouges on the bottom. Keep handle angle constant as you push across the bottom, move with your body. I do some square ones, winged ones, crotch piece ones, some natural edge from a log section, with the center of the log/pith part being the bottom of the platter.
Two hours is a lot of time. Maybe sharpening technique.
A 10-minute break in the middle of a 2-hour presentation would probably be appreciated by most, especially if the audience is mostly older folks.
Rant: My suggestions to provide a break in the middle of a demo are usually not well received by those who do the demonstrations. So, I recite a couple of things I learned while teaching for almost 40 years, which included doing a Lot of lecture demonstrations.
First, attention span: If you dwell on the same topic for more than about 15 minutes (10 minutes for kids), your audience will drift away, and you basically will be talking to yourself. Break the program up into segments in some way.
Second, time warp: Time will Fly for you, the presenter. However, it will drag on at a much slower pace for those sitting in the audience.
Third, are you special? (speaking of everyone, not a specific demonstrator) Is what you have to say so exciting and interesting that you can ignore the attention span and time warp ideas? I'll answer for you: No.
Suggestion: When you are doing a demo, watch the members of the audience. When you see some start to drift away, or even doze off, you need to do something different. It's not rudeness on their part if you are violating the attention span rule.
Further, when you're in the audience watching a demo, watch the people sitting with you. See what happens about 15 minutes into the program if it is not broken up. ZZZZzzzzz.
...experience, especially when the audience is often "up in years!" I recall training as an Army instructor and platoon sergeant, that during a long class session, an unscheduled pause and command "ON YOUR FEET" would bring the audience to a state of instant alert! I have resorted to such tactics during a few all day demos, when the subject matter (or the instructor!) was not exciting enough to hold the full attention of the audience. It's also a good way to begin a demo when following a previous demo that did not allow sufficient interval between sessions.
You are right Doc, people's attention span is not that big, I have taught spanish to adults tired after a day's work and it was a challenge until I broke the class into small sections, I'll do the same.
I agree whole heartedly Doc. I've sat in and taught upper level fire courses and you have to mix things up and break frequently or the class gets alot of sleep and you get dry mouth!
