Pm45
Pm45
Dick Hines
Pm45
Dick Hines
A friend just called and said he can pick up a PM modle 45 at a good price. He is not a turner but wants to get started. Can any of you guys give me any info on the PM45?
Re: Pm45
Re: Pm45
John Jordan
It's not much of a lathe unless its real cheap. Industrial arts lathe. Its like the 12" Deltas of that era. Short toolrest base that falls into the gap you wish wasn't there. 4 speed, 1x8 thread.
But if it gets your friend interested and turning, its good. $3-400 tops if one really wants it. And it beats a mini lathe. :)
John
Re: Pm45
Re: Pm45
Bob Holcombe
It's not much of a lathe unless its real cheap...
Ouch.
John is right. PM45's were a standard in a lot of high school shops. They took a great deal of abuse as a result. I bought my variable speed model about 5 years ago at a school district auction for $90. I put another $200 in rebuilding it...new bearings, belts, rebuilding a busted tailstock quill and a nice new coat of paint. I love mine. I use it for spindle and bowl work. I can comfortably turn 11 inch bowls over the bed and 16 inches outboard.
I would tell your friend to visit Vintagemachinery.org and look at the specs for the PM45 to make sure it is what he is looking for. If he can buy it for what John is suggesting and it doesn't need major work, I would go for it.
Re: Pm45
Wow Bob, looks like you have several ....
JamieDonaldson
...pieces of vintage machinery, back when they were made from real metal! I had forgotten how much that PM 45 looks like my old General 160V!
Re: Pm45
Re: Wow Bob, looks like you have several ....
Bob Holcombe
Jamie, the 60's vintage General and Powermatic power tools had more than a few design similarities (besides being green). Your 160 and the 260 haven't changed dramatically over the years. A good sign of quality.
The vintage machinery you see are there from necessity more than anything else. They fit my budget.
Re: Pm45
Keith Tompkins
Re: Pm45
Keith Tompkins
HI Bob, Nice lathe. The PM90 is the big brother...I see you have a Walker-Turner 900 series drill press. I also notice the belt guard is missing, which was usually thrown away >( . I have an early model in new shape, even has the guard.
Re: Pm45
Some of the best, and biggest, and fanciest...
JamieDonaldson
..bandsaws I have ever seen or used were antiques! Of course it helps to have a good quality modern blade and motor, and the skills to "fine tune" old iron!
Re: Pm45
Re: Pm45
Bob Holcombe
Jamie, the old Silver 20" BS on the right is a babbitt bearing machine. I bought it to make bowl blanks. In hindsight it was a mistake. My Delta 14" (or a chainsaw) works just fine.
Keith, actually it's a Atlas 74 drill press. I've had an eye out for a WT900 for a while without luck.
Re: Pm45
Re: Pm45
John Jordan
No offense meant, Bob. :D Yours seems to work pretty good. Now that bandsaw and drill press are another thing altogether-sweet.
There's something about an old bandsaw that is very cool. Won't do anything mine won't, but WAY cooler. If you ever come across another that size, let me know.
I put a lot of hours on the PM 45 and 90. I forgot, though that some were variable speed.
That's probably a better answer than what I gave. :)
John
Re: Pm45
Bandsaw *LINK*
Dave Peebles Lyons, Ohio
Hi Bob,
Even if the band saw you have is not what you hoped for, It is a real beauty from a "looking good" stand point. I have to admit I am in love with the sexy design of some of the older tools, and that band saw really qualifies. :)
I guess that is why I still look all the time for a old English lathe called the Union Graduate. It is not even close to my current lathe as far as turning goes, but it really has the cool factor going for it.
Best wishes,
Dave
Union Graduate lathe
Re: Pm45
Brad Vietje
Re: Pm45
Brad Vietje
Dick,
I'm going to break all the rules and disagree with John...
The old PM 45 and 90 lathes are real workhorses. The 90 has a bigger spindle, so it can handle heavier stock, but they are nice machines, and for general work, better than any mini lathe on the market (which, unfortunately, I might add, is where most beginners start out).
I'll agree that the %#$&% gap in the bed of these old machines is a royal PITA, but if you get a longer steel tool rest, you won't be tempted to drop the banjo into the gap very often. The good thing is that the bearings can be replaced, and the floor stand can be weighted to be very stable. You can do retro-fit work to add variable speed if you can't live without it, but it will take a beginner a LONG way.
If beginners asked around and found heavy old lathes like Blount, Walker-Turner, Oliver, and other machines with some solid cast iron under the hood, they'd get a lot more value than the typical light-duty mini with fairly poor design. They may have to change belts, or maintain a Reeves drive, but for heavier chunks of green wood, "more mass is more better!"
Now, it ain't no Stubby (or Oneway, or Robust or Serious), and it ain't as nice as the newer PM's, but it ain't no $6K, either!
Just one fellas 2 cents -- with apologies to one of my turning idols,
Brad Vietje
Newbury, VT
Re: Pm45
Re: Pm45
John Jordan
Brad, no reason not to disagree, its just opinions, which is what was asked for. :) Like I said, I spent a lot of hours on those lathes, and don't miss it.
I never liked General lathes either, even when they were "state of the art", but I used a lot of them, and had one in the shop for a while. There has been a lot of good work made on "industrial arts" lathes". The thing is, when that is what we used, everyone wanted, or wished for the shortcomings to be fixed. Smooth electronic drives, no gaps, bigger toolrest bases, bigger spindles, tailstocks that lock down well etc. Now we have all that, and I don't want to go back, but there's nothing wrong with it either, a lot of folks, like Bob, enjoy buying, repairing and using old stuff. :D
For $1500, one can buy the 1640 Jet, which is a great lathe, but one could buy several old PMs for that.
John
Re: Pm45
Re: Pm45
Bob Holcombe
In my case the lathe was a restoration project before I discovered the joy of turning. Sort of a chicken or egg thing. The "cool factor" of finding, owning and restoring old machines came first. Although I enjoy my PM45, I would trade it for a Powermatic 4224 in a heartbeat if I could justify the cost. But as a hobby wood turner I'm doing okay.
Re: Pm45
Dick Hines
Re: Pm45
Dick Hines
Daryl is new to turning. A friend's father has the lathe and does not use it anymore. He wants to see it. I think Daryl said $400. It is in good shape. Darly has may old Sears table saw, from when they were made in the USA and a Saers plainer that belonge to my father. These tools are well made and got worked every day for years. I can remember them in his shop when i was a kid........a lond time ago.
Dayrl reconditiond both the plainer and saw and they look like new. The only thing he knows about turning is there a lot of shavings. He pickes up mine for his chicken pen. I hope he does not get to carried away with turning. I could loose my shaving disposel. :D
Re: Pm45
Re: Bandsaw
Mac Ray
Looking for one of those here in the Northeast also.....a really neat piece of equipment...a classic...
Re: Pm45
Re: Pm45
John Jordan
I understand old machines, Bob. I don't have any interest in restoring old machines anymore, lathes at least, but I spend a stupid amount of money and time restoring old motorcycles. And they don't do anything as well as my newer one. :D
John
Re: Pm45
Dave- one of my early teachers was ...
JamieDonaldson
...Ray Key, and his main production lathe at that time was a Union Graduate, and I lusted after one for a while. These days we have many other lathe options that didn't exist 25 yrs. ago, and I understand there is a company in England that restores these old lathes, but I'll keep my Stubby now. ;)
Re: Pm45
Restoring old bikes is almost as bad as  .........
JamieDonaldson
...restoring old sports cars John!
