Split Trunk
Split Trunk
Dick Hines
Split Trunk
Dick Hines
This is the newest box. The wood is curly coolibah. It's 3 3/4'd x 5'h. The handle took longer than any of the other I have done. There were a lot of holes to drill and fill.
Re: Split Trunk
Mike Stafford
Re: Split Trunk
Mike Stafford
Another winner, Dick! I think you are heading toward a masterpiece or as some would call it, a signature piece.
The form of the box works well with this handle. I like it.
Re: Split Trunk
Dick Hines
Re: Split Trunk
Dick Hines
Thanks Mike. i have no idea where i am going with this. I do know I want to do more and that they are a blast to make. I get more enjoyment building the handle than I do turning the boxes.
Re: Split Trunk
Wonderful enjoyable piece
Re: Split Trunk
Re: Split Trunk
charlie belden
Know anybody who does lost wax castiing. Could be a means of taking this to another level. You do your trunk & branches in wax, you can put a softer wax on the surface and use coral, bark, anything that has an itneresting texture, finger prints even - into the softer wax. Whatever you do, the texture will come out in the bronze casting. Hell, if you wanted to, you could cast dragon fly wings if you wanted to.
The cool thing about doing the pattern in wax, is that you can see what you've done, with the piece it's for and make changes with almost no effort. And you can taper branches to make them more realistic - even adding a knot or two if you wish.
If casting isn't an option, I think some time with a flex shaft and a dental bur - truncated cone - could produce some interesting texture. The juxtaposition of the smooth shiny wood, with a patinated textured metal could work nicely.
Re: Split Trunk
BarbS
Re: Split Trunk
BarbS
Beautiful, Dick. I love your work with all the 'sage-brushy' look to the lids and handles. This one is great.
Re: Split Trunk
Very Cool !
Re: Split Trunk
Dick Hines
Re: Very Cool !
Dick Hines
Charlie, some of the branches are only 1/32. To small to taper. I try to taper the larger ones when i can.
Re: Split Trunk
Brad Vietje
These Are Really Beautiful, Dick!
